Thread: Coilover Confessional
Page 4 of 4 FirstFirst ... 234
Results 61 to 72 of 72
  1. #61 Re: Coilover Confessional
    GTP Level Member
    Sep 2011
    Motown
    Chats
    921
    These are designed to go way low. I designed this set up so the strut is adjusted and not the spring for the height. So there would be no need to cut the strut rod.
    Edit* - Or way high, should have about 6" of adjustability.
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  2. #62 Re: Coilover Confessional
    Feb 2013
    Detroit, MI
    Chats
    Quote Originally Posted by Speedy1973 View Post
    the only major design flaw's i see with coilovers for these cars, is that they are too damn long. We need struts that are 2'' shorter, and use a 2peice jam nut.. Not 1 with a set screw.
    BlownBigBlock (who just sold a set of coils) Had the best DIY set I've seen period. Loved his Top mount setup, and the Strange Coil over kit for a mustang... I'd love to duplicate his setup, but the limiting factor is that they only max out so far... That's were my statement of the strut body's being 2'' smaller would come into play.
    If coilover's were made to go WAY lower than they already do. You could count me in on buying a set, as long as their well thought out, and could possibly have a camber adjustable top plate.
    Woohoo I bought his set of coilovers. Still waiting on them but I'm so pumped. IMO they look better than helds or intense. They also have the helper springs and sealed bearings, but yes, the top mounts are very nice!
  3. #63 Re: Coilover Confessional
    Apr 2012
    Bancroft. Ontario, Canada
    Chats
    54
    Quote Originally Posted by GrandPrix06GT View Post
    if you EVER want to sell those after you have your fun, you Let me know! (if this other guy make's good coilovers, i'll be patiently waiting for prototypes, and could buy thoese if they appeal to me)
    i wanted them in the worst way, but i just couldn't get that kind of money together to buy them. Nice seeing that they went to someone who will appreciate the build quality.
  4. #64 Re: Coilover Confessional
    Apr 2012
    Chats
    54
    Quote Originally Posted by Classy Pontiac View Post
    Yeah, that has been done before, but you dont have much clearance to go down with the strut body it's self before smashing into the CV.. there's a Lexus coilover that are like that, but have to be modded slightly to fit the grand prix application.. (Kuntzie was the one doing that) not worth doing... I've been all over that before..
    just make a set that the strut body is SHORTER and the strut rod LONGER than what are offered now, and you'll have bites.
  5. #65 Re: Coilover Confessional
    Chats
    40719
    I talked to Koni once upon a time, they can make custom inserts for your application, it costs a few pennies, but you can shorten the shaft roughly 1.25" and the body by 1.25". Add them to some bodies and away you go.
    Your other problem as Bakerdd mentioned, when you go that low, your axles will hate their lives, probably fail so quickly its not worth it.
  6. #66 Re: Coilover Confessional
    Apr 2012
    Chats
    54
    Quote Originally Posted by Drunkie View Post
    This would be great, if somebody would try it out and tweak it till it's perfect.
    I would, but i don't have fab skills at all. F**k i can barely glue paper together and make it look good.
    as for geometry, and blowing axles twice a week lol... How thick of a spacer could you use (with a stock hood) to get some* of your axle geometry back.
  7. #67 Re: Coilover Confessional
    Jan 2009
    Tallahassee, FL
    Chats
    I wish I knew/thought of that when I got mine rebuilt. I would've gotten the housings shortened for sure.
    IIRC I've got .25" spacers top and bottom of the mounts right now, I may be able to add a couple of washers in there. I'll find out this weekend.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  8. #68 Re: Coilover Confessional
    Chats
    40719
    With these cars you need a huge drop to get to that even fender line look, to go further requires some modifications outside of just the struts. Your LCA mounts should be stronger, unless you can find balljoints that help correct the LCA's angle. Axle angles is another issue, difficult to correct.
  9. #69 Re: Coilover Confessional
    Jan 2009
    Tallahassee, FL
    Chats
    You could pay the coin for shorter axles
    77 Morris Garage B
  10. #70 Re: Coilover Confessional
    GTP Level Member
    Sep 2011
    Motown
    Chats
    921
    If you guys wanted the lowness, I could get you there with this setup. Now for axle geometry, thats on you because you wanted to go that low in the first place. Im not making these coilovers to slam the car, I am making them to go stiffer, but these coilovers will have the adjustability to go that low without modifying the strut rod and strut tube.
  11. #71 Re: Coilover Confessional
    Arizona
    Chats
    258
    it would be nice to use inverted shocks ive seen around on summit, we could get way better with travel and such before the axles would go up at a angle. As far as being slammed, i just dont bother, its my DD and smaking the subframe on **** is not my idea of fun
  12. #72 Re: Coilover Confessional
    Apr 2012
    Chats
    54
    Dalton (Killerspeed101) is at the nicest "dropped" height, i've seen on a 97-03 gp. I just feel if you could go a tad lower than that, it would look tits
    but then again, if we make coils to go that low, you'd see more and more stanced grandprixs. Which is what I actually wanna do... ever since i saw David's (bakardd) thread on here and on S/W
  1. rear coilover pics?
    By Regalgs98 in forum Brakes/Suspension/Chassis
    Last Post: 02-12-2013, 07:57 PM
  2. coilover question
    By Classy Pontiac in forum Brakes/Suspension/Chassis
    Last Post: 01-21-2013, 08:11 AM
  3. Custom Coilover Conversion. Looking for Insight Please Help
    By JeremyF89 in forum Brakes/Suspension/Chassis
    Last Post: 12-15-2012, 07:58 PM
