Thread: Traction Control Off / Stability Control Off / Service ABS System
Results 1 to 8 of 8
  1. #1 Traction Control Off / Stability Control Off / Service ABS System
    Dec 2012
    Elmwood Park, IL
    Chats
    Randomly on my 2004 Grand Prix, I will get the warnings of "Traction Control Off / Stability Control Off / Service ABS System" with the ABS light on the dashboard lighting up. If I turn the car off and back on, it is cleared for a while. I cannot find a way to replicate the issue regularly; it just happens whenever it feels like happening.
    I took my car to an AutoZone to get the computer scanned, but because it wasn't acting up at the time, the scan came back clean.
    I'm not sure what this means or what the problem is, so any information would be extremely helpful.
  2. #2 Re: Traction Control Off / Stability Control Off / Service ABS System
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Chats
    Wheel speed sensors. Take the wheels off check connections at the wheel hub.
    GPONA #1 Cyber Bully
  3. #3 Re: Traction Control Off / Stability Control Off / Service ABS System
    Pennsylvania
    Chats
    481
    Before you bother with manual diagnostics, you need to get the code read by a TechII. Find yourself a local GM mechanic that will do this for free. There's only one cheap code reader out there that will read a couple years for ABS Module codes (that I know about). A little searching might find you the answer (I'm too lazy just now).
    Once you have the code, then you'll know if you have a wiring problem, a sensor problem, a hub/bearing problem, etc. and save yourself some frustration.
    Insofar as an intermittent issue is concerned, I am most tempted to say your ABS Module is fried. They are all faulty from the factory, and all eventually fail, and you'll need to send it out for a rebuild, which should set you back about $100-$150.
  4. #4 Re: Traction Control Off / Stability Control Off / Service ABS System
    Dec 2012
    Elmwood Park, IL
    Chats
    I took it in to my mechanic today. It was a front wheel bearing assembly. $300 later, I'm good to go. Time to learn how to do maintenance on my car so I can save on labor...
    Chats
    78
    Welcome to Wbody lol you'll have to replace a few of them I'm sure. $300 isn't too bad but there's a write up somewhere in detail about how to replace it.
    04 Comp G.
  6. #6 Re: Traction Control Off / Stability Control Off / Service ABS System
    Chats
    243824
    sheeesh, a wheel bearing costs 130 ish, and a hour of your time in your drive way. the only special tool you need is a 34 or 35 mm socket, and a 1/2 breaker bar. and a pipe lol a good torque wrench is nice to have as well.
    find the how to section, and just dive in and learn, it will save you big time in the long run. these cars for the most part are pretty easy to work on. and help is only a post away.
    Chats
    78
    And if you learn to do it once it'll make it that much easier in the future. I'm sure you'll be changing another one after all it is a Wbody.
    04 Comp G.
  8. #8 Re: Traction Control Off / Stability Control Off / Service ABS System
    Sep 2011
    WV
    Chats
    I have the same issue after the struts were replaced. I also am hearing a squeak from the quick struts in the front. Im going to try and trace down the wires first, this didnt start until the struts were changed. its a common known issue on these cars that the wires to the sensors go bad. I had the guy check out the lights, and there wasnt any codes.
  1. Replies: 5
    Last Post: 02-01-2017, 09:35 PM
  2. "Service ABS, Traction Control, and Stability Control"
    By dakcornholio in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2012, 06:28 PM
  3. Replies: 14
    Last Post: 09-29-2012, 06:45 AM
  4. Traction Control/Stability System Module
    By teamfbody in forum Brakes/Suspension/Chassis
    Last Post: 06-18-2012, 07:16 PM
  5. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
