Thread: Need More Camber
Results 1 to 14 of 14
  1. #1 Need More Camber
    SE Level Member xcytmnt98gt's Avatar
    May 2012
    SWFL
    It's a 98 GT coupe my daughter drives that needs suspension work. A mechanic told her it needs tie rod ends and hub bearings up front but didn/t say anything about the rear that has way too much negative camber. Is that a trailing arm issue? Hopefully these pics give an idea of what I have.
    Thanks.
    J
  2. #2 Re: Need More Camber
    Jun 2011
    Detroit, MI
    Um. Da fuq?
    iLoveSpade
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    I don't think a trailing arm would cause that type of issue.
    This post brought to you by.....
    For all your 3800 needs:
  4. #4 Re: Need More Camber
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    maybe shot struts, as well as a sub in the trunk?
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  5. #5 Re: Need More Camber
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    You took both of those pictures with your head & camera tilted to one side by quite a bit. Take some pictures that are level with the actual ground. It honestly doesn't seem like there is an issue. But I can't really tell.
    1998 GTP : XP Cam, 3.2 Pulley, Supporting Mods<Sold>
    2001 Formula M6 : Shhhh
    2001 SSEi : New DD, Bone Stock for now
  6. #6 Re: Need More Camber
    Usually rear springs sag over time and you get more camber.
    New springs would be the solution, but if under 2* of camber, I wouldn't worry about it.
    Orange County, NY
    Ummmmm, I dunno bout that man.....I say their is an issue here....
  8. #8 Re: Need More Camber
    if you dont want to fix the springs a set of camber bolts or slotting the top hole on the strut might get you where you want to be.
    but the springs are the problem.
    Jan 2009
    Tallahassee, FL
    You can also get a little bit out of where the strut bolts to the hub spindle, there's a little bit of slop but not much.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #10 Re: Need More Camber
    Saratoga NY
    I would agree, the car is on a hill with more weight on the rear, the tires are tucking the wheel wells. That doesn't happen with stock ride height.
    Looks like a Honda with cut springs.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  11. #11 Re: Need More Camber
    Get some Olds Intrigue springs.
    That'll fix it.
  12. #12 Re: Need More Camber
    May 2012
    SWFL
    Quote Originally Posted by gmpowered View Post
    Here's some pics in the garage with the camera on a tripod. Maybe not much better. Once I get the wheels off is there anything I should see if the springs are gone, or anything else I should be looking for? I'll replace the springs and maybe the camber bolt.
    bluegtp91, what's the difference?
    Thanks!
    Right side from rear
    Right side from front...
    Leftside from rear...
    Left side from front...
    Orange County, NY
    Oh wow look at that, he took pics on a tripod and their is STILL something wrong....
    OP, the advice you've been given (other than the different pictures guy) is sound. Get new springs.
  14. #14 Re: Need More Camber
    May 2012
    SWFL
    Quote Originally Posted by copgtp View Post
    Didn't mean to be a pest. Sound advice indeed & well taken!
    Thanks.
    J
  1. 2.0 camber????
    By bandits grand prix in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2011, 09:30 AM
  2. help. wheel camber
    By 99blkgtp in forum Brakes/Suspension/Chassis
    Last Post: 04-07-2011, 09:32 AM
  3. Neg Camber on my 08 GP
    By 2008 Grand Prix in forum Brakes/Suspension/Chassis
    Last Post: 08-02-2010, 08:26 PM
  4. Camber
    By SlowM90 in forum Tires & Wheels
    Last Post: 05-14-2009, 06:01 PM
  5. camber bolts
    By nemesis in forum General Tech Discussion
    Last Post: 02-29-2008, 05:10 PM
