Thread: wheel bearing replacement?
Results 1 to 5 of 5
  1. #1 wheel bearing replacement?
    Dec 2011
    mankato minnesota
    i have a loud grinding noise coming from my front left tire just replaced the brakes and whatnot then i heard this noise like metal grinding idk thoe. im sure the bearing is toast. is it a fairly easy thing to replace? was kinda looking it up online and there saying i need air tools to get the axel bolt off? idk how long its been bad for and dont want the wheel to snap off on me and im sure a shop will charge me 3-4 hundred bucks but would rather do it myself so any help or pointers would be greatful
  2. #2 Re: wheel bearing replacement?
    Apr 2011
    Athens, AL
    The axle nut is only torqued to around 150 lbs. Get a breaker bar and you're good. It's not bad unless the bolts won't break loose. The bolts for the hub itself may cause you some problems but it is doable. If you're little, you'll want a long breaker bar for that axle nut. You'll have to pull the brake caliper and I think the mounting bracket and rotor. And I believe you'll have to pop the ball joint loose for clearance. It's not hard just takes time.
  3. #3 Re: wheel bearing replacement?
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  4. #4 Re: wheel bearing replacement?
    Dec 2011
    mankato minnesota
    i just took it. in no time to do it and i have a trip wednesday and im kinda anal about my car if somethings wrong so i wanted it done before driving a couple hundred miles... turns out both bearrings were shot cost me $497 bucks to get em replaced which sucks but it is what is i guess
  5. #5 Re: wheel bearing replacement?
    118 FT LBS for the axle nut, DONT over or under torque it, you will just screw yourself.
    never mind, you already had it done, i didnt read.
  1. camshaft bearing replacement ? how to ?
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2011, 11:24 PM
  2. snout bearing replacement
    By RICE KILLER in forum How To Write-Ups/Tech Tips
    Last Post: 08-13-2011, 09:47 AM
  3. wheel bearing hub
    By learnAsUGo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2011, 09:43 AM
  4. Supercharger Bearing Replacement!!
    By Motter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2010, 11:23 AM
  5. Wheel Bearing Replacement. Question!
    By brownb66 in forum General Tech Discussion
    Last Post: 11-11-2009, 12:04 PM
