Thread: Radiator Mount Question
Results 1 to 3 of 3
  1. #1 Radiator Mount Question
    SE Level Member TheManiac's Avatar
    Nov 2010
    Mentor, OH
    So, I noticed on the W-Bodies, the radiator side of the upper motor mount has two different styles.
    - First Style is a 4 bolt configuration to hold to the upper radiator brace.
    - Second style uses a 5 bolt configuration to hold to the upper radiator brace.
    From what I see, the 3800 drive trains use the 4 bolt style. The 3100/3400 uses the 5 bolt style. Pics of both below (one is my Monte and the other is a pic I scavenged with Google images, if it belongs to someone, thanks for posting a pic I could use to easily demonstrate my question).
    OK, guys, speculate
    Radiator Mount Question Attached Images
  2. #2 Re: Radiator Mount Question
    Nov 2011
    south carolina
    Quote Originally Posted by TheManiac View Post
    OK, guys, speculate
    The 3.1's use three bolts, not 5. I don't know why they are different but my theory is that the 3 bolt set up would be less expensive to make because it's a more simple design. The 3.8 needs the stronger mount that uses the 4 bolts... maybe?
  3. #3 Re: Radiator Mount Question
    Nov 2010
    Mentor, OH
    @Rocknnachos - Thanks. I just got to see a 3400 equipped Impala and the mount is infact a 3 bolt configuration. Based on that discovery/knowledge, I would believe the 3800 4 bolt mount is a more solid setup (less ability to flex/bend).
  1. transmission mount question?
    By hardrocrick in forum General Tech Discussion
    Last Post: 08-11-2011, 02:47 PM
  2. Engine mount question
    By goldgp in forum General Tech Discussion
    Last Post: 09-24-2010, 08:47 PM
  3. Motor mount question
    Last Post: 08-16-2010, 07:42 AM
  4. Mount question
    By kjohnson in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2009, 02:15 AM
  5. tranny swap,radiator question
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-03-2009, 01:25 PM
