Thread: Clunking noise from rear suspension
Results 1 to 9 of 9
  1. #1 Clunking noise from rear suspension
    Jul 2020
    Abbotsford, BC
    Chats
    Hi all,
    My newly acquired GTP has a clunking noise from the right rear. It doesn't do it all the time but if you hit a pothole etc on the right rear there's a clunking and banging noise.
    I've done a visual inspection and the trailing arms etc have some surface rust but are solid. The swaybar end links are also still attached. I see some seeping from the lower spring perch, so I strongly suspect the strut is bad... but my question is with bad struts will it travel enough to bang something in the back? I think it might be hitting the bump stops but due to the successions of clunks/bangs it almost sounds like it's hitting something else. Is it possible with extended travel it could smack into the exhaust.
    Regardless, replacing the two rear struts is going to happen. I don't see anything else back there that could make that kind of noise and figured that others here more familiar with the rear suspension setup may have some insight.
    Thanks!
  2. #2 Re: Clunking noise from rear suspension
    Apr 2015
    Columbus, OH
    Chats
    246
    Hopefully it's just struts. Make sure your strut towers aren't rusted out back there.
    Top Swapped 01 Imp
  3. #3 Re: Clunking noise from rear suspension
    Chats
    243824
    strut tower rotted out maybe? pull the trunk carpet down and you'll see for sure.
    try bouncing the ass end down a few time maybe you can hear it standing still.
  4. #4 Re: Clunking noise from rear suspension
    Jul 2020
    Abbotsford, BC
    Chats
    I did bounce the rear and both sides seem to be a bit bouncy, although the left side doesn't show any obvious seeping. The right side does though. I plan to lift the car so I can check wheel bearings and brakes, and while I have the wheel off I'll take a closer look at the struts.
    This area is not known for a rust belt... I looked all over the car and there's no rust on the body itself. The exhaust is in bad shape and there's surface rust on things under the car, but not the gobs of flaking rust like when I used to live further north in the snow belt. I cleaned out the trunk and there's no rust in the spare tire wheel well, to give you an idea, but thanks for the tip. I'll peel back the covers today or tomorrow in the trunk to have a closer look.
  5. #5 Re: Clunking noise from rear suspension
    Oct 2014
    portland oregon
    Chats
    507
    I have the same problem.. towers are okish. Changed everything but the hub and it still does it
    I decided not to care anymore lol.
    Give your lateral bars a wiggle they shouldn't move
    Sent from my SM-N920V using Tapatalk
  6. #6 Re: Clunking noise from rear suspension
    GT Level Member mguzzo's Avatar
    Buffalo NY
    Chats
    25
    maybe the muffler hangars are a bit stretched and the exhaust is banging around.
    Or the hooker in the trunk is trying to get out.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  7. Thanks bandook thanked for this post
  8. #7 Re: Clunking noise from rear suspension
    May 2020
    Pittsburgh
    Chats
    a REALLY bad strut will make a banging noise. at a certain point, the shaft will become loose in the tube, and rattle around. this is after a long time of neglect though, and i've never seen it happen to a rear, only front. nevertheless, it's possible.
    sway bar links would be first suspect in my eyes. visually okay can still be loose inside the ball&socket joint. if you're changing struts, change them as well.
    my $.02
  9. Thanks danf thanked for this post
  10. #8 Re: Clunking noise from rear suspension
    Jul 2020
    Abbotsford, BC
    Chats
    Well, I finally had time today to take a closer look at my purchase. I checked each wheel, wheel bearings seem to be OK. Brakes look to be all new. I shook the sway bar on the passenger side and heard a clunk. The exhaust isn't loose, I shook it around but holy is the exhaust swiss cheese. I'm going to have to get that addressed when I put tags on it.
    The springs look OK - I don't think I need to replace those. I'm going to order two new rear struts and two rear sway bar end links.
    Out of curiousity I did look at the rear strut towers. I'm pretty sure this is a local car as there's no rot I can see. (Attached picture.)
    I think replacing those couple bits in the rear suspension is all I need to do for now.
    Clunking noise from rear suspension Attached Images
  11. #9 Re: Clunking noise from rear suspension
    Jul 2020
    Abbotsford, BC
    Chats
    Update:
    I learned that really bad struts can make a farting noise today. There was no oil etc left in that strut. I decided to try it to see if it was really bad and it fell down to the bottom of its travel making a farting noise, then a loud CLANK noise. The sway bar end link on that side also had a frozen ball socket, hence the banging and popping noise.<br>
    This car must have been a local car, like almost no rust. I was surprised how easy it was to get apart. Attached a few pics of the strut tower, and the bolts for the strut to the knuckle bit.
  1. Rear Suspension clunking noise repaired (finally)
    By Crispykit in forum General Grand Prix Discussion
    Last Post: 10-28-2013, 03:21 PM
  2. Rear Suspension Noise Driving me Crazy HELP
    By 94GrandPrixSE in forum Brakes/Suspension/Chassis
    Last Post: 01-22-2013, 10:44 PM
  3. clunking noise in right rear
    By chenango kid in forum General Tech Discussion
    Last Post: 10-13-2012, 09:26 AM
  4. Help On Clunking Noise In Rear Side
    By xxquortneexx in forum Introductions/Noob Questions
    Last Post: 06-01-2012, 09:46 PM
  5. clunking raddleing noise in rear with vid
    By gtcoup in forum Brakes/Suspension/Chassis
    Last Post: 03-05-2012, 10:10 PM
