Thread: ABS Issue without code
Results 1 to 7 of 7
  1. #1 ABS Issue without code
    SE Level Member sn95gt50's Avatar
    Jul 2008
    Chats
    My daughter complained that the anti-lock brakes are kicking in when braking, more prevalent during cornering. She is not getting any kind of indicators on either the dash or the DIC. I assume that I have a sensor going bad in one of the bearings, but, how do I determine which one. Any diagnostics I can perform to at least narrow it down? Or, anything I can check?
    I did a search and didn't find much.
    Thanks in advance,
    John
  2. #2 Re: ABS Issue without code
    Jul 2008
    Chats
    I have the Torque App on my phone for my OBD II Elm 327, is it possible to get individual wheel speeds
  3. #3 Re: ABS Issue without code
    Chats
    83662
    You will probably require a scan tool that can read the ABS module and it's functions. As far as I know you can't do that with the phone apps.
  4. #4 Re: ABS Issue without code
    Chats
    243824
    ChevroSys Scan Free - Apps on Google Play this app will read abs codes. sounds like the abs module has gone bad. the abs will pulse under your foot when driving slow like trying to park.
  5. #5 Re: ABS Issue without code
    Jul 2008
    Chats
    Found it, surprised it didn't throw a code. Found electrical tape on the abs sensor wires where it was secured to the control arm. I removed the tape and found that a new connector had been spliced in, different colored wires. The connections were very corroded. I cut out the crimp connector and cleaned it up and reconnected and sealed up. Took a test drive and no pulsing any more.
    Gotta love free fixes.
    Thanks all!
  6. Likes Scottydoggs liked this post
  7. #6 Re: ABS Issue without code
    Apr 2014
    commerce twp,mi
    Chats
    i was going to say it seems like a lot of abs code things come from the front-where them wires move a lot and theres more weight.
    08 grand prix NA3800
  8. #7 Re: ABS Issue without code
    Jul 2008
    Chats
    I agree, started front DS, nothing stuck out, then front PS. Still no signs of the symptom, still surprised if didn't give any indications via the DIC.
    Thanks all,
    John
  1. 2001 grandprix gt p0446 code..no converter but no P0420 code...
    By chicagochuck in forum General Grand Prix Discussion
    Last Post: 12-13-2016, 01:59 PM
  2. p0135 code help with my new sensor issue
    By willie14 in forum General Grand Prix Discussion
    Last Post: 12-10-2016, 10:36 AM
  3. 2008 Grand Prix Base Possible injector issue Code P0305
    By smoraq in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-24-2016, 04:22 PM
  4. HELP Needed! Car surging P0102 code and P1655 code im STUMPED
    By 97gtpjoe in forum General Tech Discussion
    Last Post: 02-06-2014, 12:15 PM
  5. Code, p0336, tach quits and Traction control issue
    By jimtjr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2012, 12:04 PM
