Thread: Steering Shaft Clunk.
Results 1 to 10 of 10
  1. #1 Steering Shaft Clunk.
    Feb 2020
    UT
    I've been searching through the forums and found that my Intermediate Steering Shaft is whats causing the clunk in my steering wheel. I've heard some people saying greasing it will get rid of the clunk which makes sense, but does it actually fix the problem? If greasing it is the only thing I would need to do then that would be great but if the shaft needs repaired then I would like to fix it rather than just covering it up.
  2. #2 Re: Steering Shaft Clunk.
    you replace it, cant repair it.
    get your ball joints checked out first, they tend to clunk as well.
  3. #3 Re: Steering Shaft Clunk.
    Feb 2020
    UT
    Ok, can you help me find a decent quality one? The only ones I can find are doorman I can’t find any from GM. What one would you recommend?
  4. #4 Re: Steering Shaft Clunk.
    Feb 2020
    UT
    Also, is there a risk of the shaft failing completely and losing steering while driving or will I be ok to drive it until I can replace it?
  5. #5 Re: Steering Shaft Clunk.
    not a chance at all. its a slip joint thats clunking, if thats it. i chased a clunk down, last thing i fixed was the ball joints, no more clunk. if you never did lower control arms just change em. 100 for the pair on line for new a arms.
  6. #6 Re: Steering Shaft Clunk.
    Feb 2020
    UT
    Ok well yeah I’m pretty sure it’s the ISS as it only clunks when turning the wheel but I will check the ball joints just to be safe. Thanks for the help.
  7. #7 Re: Steering Shaft Clunk.
    if you feel play in the wheel stopped engine off and a slight clunk, it could be the rack too. i had one with internal slop. tie rods can also click.
  8. #8 Re: Steering Shaft Clunk.
    Apr 2015
    Columbus, OH
    Hate to be that guy, but I've had 2 cars with iss clunk. Both of them I just cleaned and packed with new grease and never heard the clunk again. I'm sure there's a chance it won't work, just saying what worked for me.
    Top Swapped 01 Imp
  9. #9 Re: Steering Shaft Clunk.
    Feb 2020
    UT
    How did you access it to grease it? And also I torqued down all my wheels and I think whoever sold me the car didn’t tighten them down enough because it doesn’t really clunk anymore. It seems like it does a tiny tiny bit but it’s like 95% better so one of the wheels must have been loose. Still might grease up the ISS though.
  10. #10 Re: Steering Shaft Clunk.
    LOL .. I once got fresh sneakers and thought I had an axle going from the noise on a corner. Found wheels to be loose, kinda scary isn't it?
    Glad you figured it out. I was also going to suggest jacking it up and checking the rack before doing any work.
  1. New half shaft clunk
    By klimtrack in forum General Tech Discussion
    Last Post: 10-13-2016, 05:09 PM
  2. Loose steering after replacing intermediate steering shaft on 06 GP GT
    By Tross901 in forum Other 3800 Powered Cars
    Last Post: 06-03-2015, 10:56 AM
  3. Clunk when shimmying Steering Wheel
    By stocker in forum Brakes/Suspension/Chassis
    Last Post: 10-16-2013, 11:03 AM
  4. [?] steering column plastic / intermediate steering shaft question
    By localhost127 in forum General Tech Discussion
    Last Post: 06-10-2013, 08:33 PM
  5. clunk in steering wheel
    By fluffy54935 in forum General Tech Discussion
    Last Post: 11-12-2010, 03:58 PM
