Thread: Building new FE3's, mount question
Results 1 to 6 of 6
  1. #1 Building new FE3's, mount question
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    GM's parts diagrams show a wedge shape spacer in with the mount, like #4 on this -
    Will I need to buy that wedge thing, GM 22167000, or will it be in with the mounts depending what I buy? These look slightly different shape than those pictured in Rockauto's mount kits.
    They're only about $8/ea so it's an easy order if I need em. Thanks for any input!
  2. #2 Re: Building new FE3's, mount question
    May 2016
    MN
    I just went ahead and bought these off ebay. I don't know if they're getting scarce. Well, I'm not even sure I'll need them for that matter.
    There was also a couple "Shield" items I wasn't too sure about. I found the OE bellows, so I may need them.
    It seems like it should be very straightforward, but it just isn't that simple finding the parts to piece these together.
    I plan on making a list of the required AC Delco part numbers for this project. Might even do a write-up, amount of free time pending.
    Part #'s so far:
    Strut - GM 506273
    Dust Shield(?) - GM 22189840
    Wedge/Isolator - GM 22167000
    Bellows - GM 901083
  3. #3 Re: Building new FE3's, mount question
    Nov 2012
    Madison
    You wont need the angle spacer if you get Monroe mounts. I had bad luck with groaning using those.
    I would buy the AC Delco professionals and re-use the plastic spacer.
    It looks like most mount kits manufacturers think you will re-use the old spacer.
    It does get pricey if you are replacing 100,000 original isolators, etc.
    Make sure you add more grease to the bearings i
    Anyway here is a pic I found of a Monroe assembly.
  4. #4 Re: Building new FE3's, mount question
    May 2016
    MN
    That pic will be useful later, and I actually didn't think of grease yet either. Thanks on both accounts.
    Think I'm gonna pull one side, take the spring off and see what's layin there. Then I can compare with what I plan to order and ask questions.
    Just wanna make sure it's all here.
  5. #5 Re: Building new FE3's, mount question
    Nov 2012
    Madison
    I checked my Rockauto order from when I did it a few years ago.
    This is all I needed to get it done,front and back.
    The Monroe strut mate kits are probably your best deal. I didn't grease mine before install.
    I learned a lesson. I replaced them with Duralast from Autozone just because I decided to remedy it one day. Those I greased.
  6. #6 Re: Building new FE3's, mount question
    May 2016
    MN
    Ok, I have most the parts on their way here. spazz, you mentioned grease. I gather the bearing needs it, but did you grease any other areas?
    Read maybe do the insulators too? Asking cus a friend just did them and has an awful noise when turning the strut by hand.
    Thanks again!
  1. Radiator Mount Question
    By TheManiac in forum Brakes/Suspension/Chassis
    Last Post: 12-13-2011, 05:57 PM
  2. transmission mount question?
    By hardrocrick in forum General Tech Discussion
    Last Post: 08-11-2011, 02:47 PM
  3. Engine mount question
    By goldgp in forum General Tech Discussion
    Last Post: 09-24-2010, 08:47 PM
  4. Motor mount question
    Last Post: 08-16-2010, 07:42 AM
  5. Mount question
    By kjohnson in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2009, 02:15 AM
