Thread: Looking for recommendations on Comp G suspension upgrades
Results 1 to 9 of 9
  1. #1 Looking for recommendations on Comp G suspension upgrades
    SE Level Member derpyimp's Avatar
    Nov 2017
    Utah
    Chats
    73
    I'm considering upgrading the suspension on my 2004 Comp G in the near future. I've been reading a lot of forum posts on suspension upgrades, but everybody seems to recommend something different and most threads are for 97-03 GPs, which I know have a softer suspension than a Comp G. So some upgrades for earlier GPs may not be as much of an upgrade for my car.
    Mainly what I want is more stability in longer, high-speed turns, as it feels like my car gets a little antsy in those situations. It doesn't feel coordinated, almost like the car wants to wander a bit, and it feels like hitting a small bump would be enough to break traction and start sliding. The car has been aligned in the last year and has quality tires. It just doesn't inspire confidence. I just want a few parts, not a complete overhaul, but something that is a noticeable upgrade in the $300 to $500 range. My car currently has about 169k miles and most if not all of the suspension is original. What would you guys recommend?
    '04 GTP Comp-G - 14.871 @ 93.30 (6600 ft DA) - 3.6 MPS, SD headers w/ high-flow cat, Gutted stock airbox, Transgo shift kit, AL 104s, 180 tstat, GMPP front sway bar, poly control arm bushings, Tune by Dyno Brian
  2. #2 Re: Looking for recommendations on Comp G suspension upgrades
    SE Level Member wickedfrisone's Avatar
    Jun 2018
    New England
    Chats
    129
    Not sure if ZZP's strut tower brace might be something to interest you? Claims to add structural rigidity and reduce chassis flex during cornering, which if I ready correctly sounds like something that bothers you at the moment
    ZZP Front Strut Tower Brace (Strut Tower Bar) – ZZPerformance
    2004 Grand Prix GTP Comp G, aka Pumpkin
  3. #3 Re: Looking for recommendations on Comp G suspension upgrades
    Nov 2017
    Utah
    Chats
    73
    Thanks for the suggestion. I didn't get any replies here, so I ended up getting a few things based on what people said elsewhere. I installed front and rear strut tower braces, just the OE GM kit where you have to drill holes in the strut towers, but it actually made a noticeable difference. Pretty good for $43. Maybe ZZP braces are nicer, but I didn't want to shell out $80 each for those. I also have new trailing arms and lower control arms too with a custom bushing setup that I have yet to install.
  4. #4 Re: Looking for recommendations on Comp G suspension upgrades
    Jun 2018
    New England
    Chats
    129
    Well that's great that there's cheaper OE ones, I actually wasn't aware of those. I would imagine they would make a good difference
  5. #5 Re: Looking for recommendations on Comp G suspension upgrades
    Nov 2017
    Utah
    Chats
    73
    Amazon.com: Chevrolet Performance 12498648 Strut Tower Braces: Automotive
    Definitely worth the money if you want a mod for $43 shipped.
  6. #6 Re: Looking for recommendations on Comp G suspension upgrades
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Chats
    1417
    If you haven't, you could replace struts being they're fourteen years old. I guess maybe that's not really a "mod" tho
  7. #7 Re: Looking for recommendations on Comp G suspension upgrades
    Nov 2017
    Utah
    Chats
    73
    Quote Originally Posted by SaukRapids View Post
    I have definitely considered that, but with no bouncing or visible leaks/damage/bad seals, I'm not gonna worry about it yet. They're certainly stiff enough for me at this point. I'm honestly surprised that they've held up this well. 172k on the car currently.
  8. #8 Re: Looking for recommendations on Comp G suspension upgrades
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Chats
    10330
    What made the biggest difference for me was the strut tower braces and the biggest solid sway bars I could find... Lol
    I got the 34mm solid front sway from Dorman, the ADDCO 22mm solid rear sway, Moog end links and poly bushings all around.
    The car I'm about to pull those off of could take corners like you would not believe... I could take corners at 60 that before would scare the crap out of me at 35.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  9. #9 Re: Looking for recommendations on Comp G suspension upgrades
    Nov 2017
    Utah
    Chats
    73
    Thanks for the input. I think upgraded sway bars with poly bushings will be my next handling upgrade after I get the control arms and trailing arms installed. And after I come up with some more money lol
  1. 05 comp g suspension upgrades
    By pontiacgt500 in forum Brakes/Suspension/Chassis
    Last Post: 12-30-2017, 11:15 PM
  2. suspension upgrades for 04+ GPs
    By gxp revenge in forum Brakes/Suspension/Chassis
    Last Post: 06-03-2014, 09:05 PM
  3. 04+ GP suspension upgrades?
    By painthorsemoe in forum Brakes/Suspension/Chassis
    Last Post: 03-05-2014, 11:50 AM
  4. Need Suspension upgrades
    By Luda in forum Brakes/Suspension/Chassis
    Last Post: 04-15-2010, 09:17 PM
  5. 1995 GP suspension upgrades?
    By mikefeelsgood in forum Brakes/Suspension/Chassis
    Last Post: 08-18-2009, 04:50 PM
