Thread: Vibration during braking - thoughts?
Results 1 to 5 of 5
  1. #1 Vibration during braking - thoughts?
    SE Level Member derpyimp's Avatar
    Nov 2017
    Utah
    Hey guys, I've got a quick dash cam video for you to watch. I was out driving down the canyon, pushing the car a bit but nothing too crazy. During the last two or three turns I started to notice a slight vibration when I was on the brakes, then it got really bad as I was on the last turn before the light. I couldn't replicate it again after that. Any ideas what it might be? I don't think it's the ABS acting up. It felt different than that. Almost like something coming loose but I don't know what.
    Link to a video of it. The vibration is quite audible for a few seconds.
    Google Photos
    Thanks
    '04 GTP Comp-G - 14.871 @ 93.30 (6600 ft DA) - 3.6 MPS, SD headers w/ high-flow cat, Gutted stock airbox, Transgo shift kit, AL 104s, 180 tstat, GMPP front sway bar, poly control arm bushings, Tune by Dyno Brian
  2. #2 Re: Vibration during braking - thoughts?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Check the caliper bracket bolts, I've had one back out completely and disappear, it was the top bolt, front passenger side.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: Vibration during braking - thoughts?
    Nov 2017
    Utah
    I didn't have time today to actually jack up the car and look closely at anything, but all the caliper bracket bolts are present and appear fully tightened from a visual inspection. I drove the car as usual today and still could not replicate the problem. I wonder if it was caused by the car getting hot somehow. I guess I won't worry about it again unless I see it happen again.
  4. #4 Re: Vibration during braking - thoughts?
    Likely it was as you think. Without knowing pad composition and quality of rotor, it's all possible. If you can't replicate it.. smile and keep on driving
  5. #5 Re: Vibration during braking - thoughts?
    Nov 2017
    Utah
    That's the plan I guess. I'm on what I suspect are original or OE replacement rotors, and I put PowerStop Evolution ceramic pads on the fronts shortly after I got the car (I think I still have cheap organics on the rears that the used car dealer installed). I wasn't on the brakes all that much going down the canyon though.
  1. Vibration During Braking
    By rdenn58 in forum General Grand Prix Discussion
    Last Post: 09-09-2014, 04:59 PM
  2. Shaking and braking
    By Scoty in forum Brakes/Suspension/Chassis
    Last Post: 01-31-2013, 08:57 AM
  3. Braking Issue
    By juggalette79 in forum Brakes/Suspension/Chassis
    Last Post: 04-24-2012, 08:49 PM
  4. lights dim when braking
    By hourang in forum General Tech Discussion
    Last Post: 01-05-2010, 01:51 PM
  5. braking problem
    By beastin1 in forum Brakes/Suspension/Chassis
    Last Post: 12-11-2008, 09:25 AM
