Thread: Power Steering/Rack & Pinion Cooler
Results 1 to 3 of 3
  1. #1 Power Steering/Rack & Pinion Cooler
    Jan 2018
    US
    Any info on a power steering cooler install? Seen some mentioning also having a cooler for power steering/rack & pinion? Curious on all aspects of that if anyone has pics and info of why?
    Sent from my SM-N950U using Tapatalk
  2. #2 Re: Power Steering/Rack & Pinion Cooler
    HUDSON
    There exists a section of line on the car, I think it's the return line to the pump from the rack, it has extra length (steel) and runs next to sub-frame and engine, I dont know how effective it is at removing heat from the fluid, it's just round steel line with NO cooling fins on it, but I think this part of the line is intended to cool the fluid somewhat. If you wanted more cooling, it would not be hard to install a small cooler. Late 90's Ford Explorers have a nice size cooler for the power steering fluid, it would not be hard to snag one off from a salvage yard and put on with a little creativity.
    I can see the need for extra cooling under certain driving conditions. I delivered NEWS papers one night for a friend, and all the steering I had to do made the fluid hot as (you know what), I had too change the fluid not long after that.
  3. #3 Re: Power Steering/Rack & Pinion Cooler
    Jan 2018
    US
    Funny you say that because I got this cooler off a Ford Explorer for my trans but I'm using a TruCool Max for my trans now. So maybe I can somehow use this to cool my steering [emoji848] Wonder will it work. I'll have to turn my creative juices on like you said. Longevity is what I'm shooting for
  1. Rack and Pinion/Power Steering Pump ??
    By hamay75 in forum General Grand Prix Discussion
    Last Post: 03-06-2017, 12:47 PM
  2. Steering/rack and pinion
    By RazerDev in forum General W body
    Last Post: 01-24-2017, 05:38 AM
  3. Can't connect rack and pinion to steering
    By vagk1234 in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2014, 08:31 AM
  4. Can rack and pinion cause wobble in steering?
    By teejay in forum General Tech Discussion
    Last Post: 04-14-2013, 06:45 PM
  5. Rear knock sensor / power steering pump / rack & pinion question
    By miwalter928 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2012, 09:38 AM
