Thread: 2004 GP GTP Comp Group rear brake calipers
Results 1 to 3 of 3
  1. #1 2004 GP GTP Comp Group rear brake calipers
    Nov 2012
    Tracy, CA
    Chats
    I need to change my rear calipers and I See that there are two versions of these. One of the AC Delco calipers available shows it is for the cars with the Ride and Handling package (FE2) [ PN 1722416 for the right-rear ]. Is that the one used on the Comp G cars ??? Also I see mention of of caliper inlets of either M10x1.0 or M10x1.5. How do you know which to buy for the car ? Too many variables for something that should be simple.......
  2. #2 Re: 2004 GP GTP Comp Group rear brake calipers
    SE Level Member derpyimp's Avatar
    Nov 2017
    Utah
    Chats
    73
    I replaced my rear calipers recently and I have the same car as you. The GTP/Comp G uses the same calipers as the base model Grand Prix, so it should be one size fits all. I bought these calipers on eBay a few months ago and installed them. They fit like stock and have held up fine since then. Just had to paint them something close to the OE color so I can still pretend I have a racecar lol
    '04 GTP Comp-G - 14.871 @ 93.30 (6600 ft DA) - 3.6 MPS, SD headers w/ high-flow cat, Gutted stock airbox, Transgo shift kit, AL 104s, 180 tstat, GMPP front sway bar, poly control arm bushings, Tune by Dyno Brian
  3. #3 Re: 2004 GP GTP Comp Group rear brake calipers
    Nov 2012
    Tracy, CA
    Chats
    Quote Originally Posted by derpyimp View Post
    Thanks! I will take a look at those. I am not sure why two different inlet port thread sizes are mentioned on some websites...
  1. GXP Rear Brake Calipers
    By Acdc88 in forum Wanted To Buy - Parts
    Last Post: 08-19-2016, 09:13 AM
  2. No brake fluid to rear calipers
    By South Central in forum Brakes/Suspension/Chassis
    Last Post: 08-17-2013, 08:20 PM
  3. A little 2004 rear brake help??
    By johnb62 in forum Brakes/Suspension/Chassis
    Last Post: 07-02-2012, 10:25 PM
