Thread: Sway bar question
Results 1 to 3 of 3
  1. #1 Sway bar question
    Feb 2018
    Canada
    Chats
    Hey guys, i changed my sway bar bushings awhile back along w the end links. Im tryinv to hunt down a vibration when i let off the pedal. As soon i give it throttle again the vibration goes away, anyway i noticed my end links were loose so i changed them. The passenger side end link was a pia, i had to use a long pry bar to pull it down just to start the nut. But the drivers side went on fine. Im thinking wjen i changed the bar i put it in backwards..... when im looking at the side theres a slight curve down from the bushing to the control arm, is this right?? I ran out of patience yesterday lol. Help is always appreciated here. Thanks
  2. #2 Re: Sway bar question
    Mar 2014
    Tucson
    Chats
    2468
    Moved to proper section.
  3. #3 Re: Sway bar question
    Oct 2011
    Toledo, OH
    Chats
    956
    Front or rear? My front looks like it curves upward. You should be tightening the endlinks with the tires on the ground though. I've put the rear in upside down once, it's way harder to install and nothing lines up and it hits the mufflers.
  1. question about gmpp sway bar.
    By Grimsin in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2015, 04:29 AM
  2. GMPP sway bar question
    By 13aceofspades13 in forum Brakes/Suspension/Chassis
    Last Post: 10-08-2013, 01:41 PM
  3. Addco sway bar question
    By SomeDudeAtHome in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2013, 06:45 PM
  4. Sway bar question
    By nick eversole in forum Brakes/Suspension/Chassis
    Last Post: 08-08-2011, 09:03 AM
