Thread: Best bang for buck for replacement struts on 2002 GTP?
Results 1 to 6 of 6
  1. #1 Best bang for buck for replacement struts on 2002 GTP?
    SE Level Member Garandpa's Avatar
    Oct 2016
    Davisburg, MI
    Chats
    I need struts on my 2002 GTP with 137k miles because the right one is hopping when I hit anything rough. Not sure what else is wrong with it, but the boot has separated from the shock. I've found a number of replacement parts, but don't want to change my ride height or spring rate (nor break the bank). What about these from ZZP:
    Drop in Strut/Spring Combo – ZZPerformance
    Or this kit from Am Autoparts?:
    2000 2000 Pontiac Grand Prix 8 Piece Set Suspension Kit - AM-740055916 at AM Autoparts
  2. #2 Re: Best bang for buck for replacement struts on 2002 GTP?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Chats
    These are the best bang for your buck struts and are recommended by lots of people in the 3800 community.
    These would be the fronts:
    Amazon.com: KYB SR4002 Strut Plus Complete Corner Unit Assembly: Automotive
    You would also need for the rears:
    KYB-SR4003 & KYB-SR4004
    Amazon says about 353$ with free prime shipping. (If you dont have prime you can sign up for free trial)
    Ive heard only bad things about Zzp and Monroe quick struts
    Sent from my LG-H830 using Tapatalk
  3. #3 Re: Best bang for buck for replacement struts on 2002 GTP?
    Oct 2016
    Davisburg, MI
    Chats
    So KYG recommends their Excell-G struts for the GTP application, which is what ZZP is selling complete for $299. Are the SR4xxx series an upgrade? They're certainly a lot more expensive. Not sure how you came up with $353, since each strut is over $100 each, unless that was for fronts only.
  4. #4 Re: Best bang for buck for replacement struts on 2002 GTP?
    Oct 2016
    Davisburg, MI
    Chats
    Quote Originally Posted by Garandpa View Post
    Correction: ZZP has KYG Excel-G struts pictured in their ad, but ships Monroe struts.
  5. #5 Re: Best bang for buck for replacement struts on 2002 GTP?
    Oct 2016
    Davisburg, MI
    Chats
    I went with these struts and I could not be happier. My GTP rides like new! I also replace the Lower Control arms with Moog LCA's as well as the torsion bar links.
  6. #6 Re: Best bang for buck for replacement struts on 2002 GTP?
    Oct 2016
    Davisburg, MI
    Chats
    That is to say, I went with the KYG struts recomended by Suitercrew. Easy install and great feel on the road.
  1. Best mods to get the most bang for your buck?
    By HPQueen in forum 5.3L V8 (LS4)
    Last Post: 12-07-2013, 03:36 PM
  2. Bang for the buck!
    By JunkBird69 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2011, 12:01 AM
  3. Best bang for buck?
    By Edagimo in forum Engine
    Last Post: 06-16-2010, 09:22 PM
  4. Desktop video card: Best bang for the buck?
    By BackInBlack in forum Off Topic Discussion
    Last Post: 11-12-2008, 10:11 PM
  5. Best Bang for your buck on speakers?
    By RichCresci in forum Audio, Security & Visual Electronics
    Last Post: 10-02-2008, 04:49 PM
