Thread: Replace rear brake pad and rotor on 2005 Grand Prix base
Results 1 to 5 of 5
  1. #1 Replace rear brake pad and rotor on 2005 Grand Prix base
    Oct 2012
    USA
    I plan to replace the rear rotor and brake pads on a 2005 Grand Prix base model. I know that the piston has to be screwed in with a special tool that I can rent from AutoZone or Advanced Auto Parts. My question is whether I need to take out the parking brake cable? I have seen two videos on youtube and it seems I can just loose the four bolts, screw in the piston, replace the pads and rotors, and do not need to do anything with the parking brake. Is it true? Any input is appreciated.
  2. #2 Re: Replace rear brake pad and rotor on 2005 Grand Prix base
    no need to remove the e bake cable.
  3. #3 Re: Replace rear brake pad and rotor on 2005 Grand Prix base
    GTP Level Member
    Oct 2014
    A needle nose pliers will work to screw in the Pistons.
  4. #4 Re: Replace rear brake pad and rotor on 2005 Grand Prix base
    Oct 2012
    USA
    Thanks a lot!
  5. #5 Re: Replace rear brake pad and rotor on 2005 Grand Prix base
    Oct 2012
    USA
    Quote Originally Posted by markpa View Post
    Thanks! Yeah, I saw a video on Youtube and using a needle nose pliers is just as easy as using the special tool.
  1. 2005 Grand Prix Base
    By kyliek23 in forum Members Rides
    Last Post: 03-20-2014, 09:23 PM
  2. 2005 Grand Prix GTP Rear Brake Issue
    By whitefeathersnpr in forum Brakes/Suspension/Chassis
    Last Post: 08-24-2012, 07:40 AM
  3. 2005 Grand Prix, rear brake frustration
    By gt2003 in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2012, 04:09 PM
  4. how to replace rear speakers in 2005 grand prix?
    By Magnaflow GP in forum Audio, Security & Visual Electronics
    Last Post: 10-01-2011, 05:01 PM
