Thread: Speaker Grilles?
Results 1 to 9 of 9
  1. #1 Speaker Grilles?
    Apr 2012
    Bancroft. Ontario, Canada
    Chats
    54
    Now i know this may be in the wrong section to be asking this, but on both the front (doors) and rear (deck) are the plastic grilles covering the speakers. Do they just simple pop off or will i have to take my entire door skin and rear deck skin off to access the speakers?? Help greatly appreciated
    (would be out at the car right now figuring this out, but it's currently parked elsehwere and dont have access to it for the next few days)
    Thanks a bunch
    Dec 2010
    DMV
    Chats
    174
    Door speaker covers pop out from
    Inside the door so door removal is necessary. As for rear ones I dont know because I never removed mines. Still rocking stocks. Lol
  3. #3 Re: Speaker Grilles?
    Chats
    64942
    Rears require rear seat removal.
  4. #4 Re: Speaker Grilles?
    Houston
    Chats
    376
    Yep, fronts need the door panel removed. The rears need the deck lid removed. You just remove the back seats which only requires you releasing the lower seat and lifting it out. Then 2 10mm bolts that hold in the back rest, then lifting it up and out. It can be a PITA putting the back rest back in though.
    Chats
    64942
    Wuuuut four 18 mm, two bolts, two nuts.
  6. #6 Re: Speaker Grilles?
    Houston
    Chats
    376
    All three of my Prixs were just 2 10mm bolts that hold in the bottom of the backrest. After they're out, just pull up and out on the seat.
    Edit: 2 10mm nuts not bolts..my bad.
  7. #7 Re: Speaker Grilles?
    Chats
    64942
    The seat belts could not be held in by 10 mm nuts.
  8. #8 Re: Speaker Grilles?
    Houston
    Chats
    376
    I've never had to remove the seat belt nuts. Just these ones. There's one on the middle of each side.
  9. #9 Re: Speaker Grilles?
    Chats
    64942
    That is strange indeed.
  1. Monsoon System - What ohm speaker do I need for the center dash speaker?
    By Schmitty in forum Audio, Security & Visual Electronics
    Last Post: 12-22-2011, 07:01 AM
  2. Rear Deck Speaker Grilles
    By SlowNA06 in forum Audio, Security & Visual Electronics
    Last Post: 05-25-2010, 12:18 PM
  3. New Rear Deck Speaker Grilles Needed For 2002 Grand Prix GT
    By LoveMyGPGT in forum Audio, Security & Visual Electronics
    Last Post: 04-01-2010, 02:32 PM
