Thread: Navigation unit installed date go bye bye. HELP!!!
Results 1 to 20 of 20
  1. #1 Navigation unit installed date go bye bye. HELP!!!
    SE Level Member hipposheriff's Avatar
    Michigan
    Chats
    So I just installed a Kenwood dnx6160 in my GXP and everything works great minus the fact that my info screen where my date used to be wont save. The compass and the temperature still show up but where the date used to be its just a dotted line. I reprogram everything, it shows up for about 5 seconds, then the dotted line comes back. Any ideas?
  2. Advertisement
  3. #2 Re: Navigation unit installed date go bye bye. HELP!!!
    Donating Users
    Chats
    64942
    either its internal flash memory is fubar'd or its not getting 12+ constant when the powers off.
  4. #3 Re: Navigation unit installed date go bye bye. HELP!!!
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    Chats
    What does Kenwood say? I'm sure they have a tech support line.... cuz I don't know enought about it to tell ya.
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  5. #4 Re: Navigation unit installed date go bye bye. HELP!!!
    Feb 2009
    Virginia
    Chats
    4010
    Quote Originally Posted by hipposheriff View Post
    Are you talking about your DIC? The DIC will not retain time/date function once you've installed a third party stereo. However, if it's the Kenwood unit that isn't functioning with time/date function then it does not have 12v always on wired appropriately or it's defective.
    11 is louder than 10!
  6. #5 Re: Navigation unit installed date go bye bye. HELP!!!
    Michigan
    Chats
    Quote Originally Posted by I800C0LLECT View Post
    yes the DIC. The unit is fine, i guess just something I'll have to live with. No biggie just one of those things you turn your head at wondering why. I'm also having to custom fabricate a trim piece since no one makes a double din kit for the car. I'll post some pictures when i'm happy with it.
  7. #6 Re: Navigation unit installed date go bye bye. HELP!!!
    Joliet, IL
    Chats
    metra definately makes an 04+ double din kit...
    http://www.amazon.com/Metra-95-3527-.../dp/B0014GII0I
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  8. #7 Re: Navigation unit installed date go bye bye. HELP!!!
    Joliet, IL
    Chats
    they make a harness adapter to retain these things if im not mistaken.
    00 Silvermist GTP
  9. #8 Re: Navigation unit installed date go bye bye. HELP!!!
    Grand Blanc, MI
    Chats
    Quote Originally Posted by BoostJunki3 View Post
    Same exact thing when I installed my Pioneer Avic unit in my '07 gxp. The retention kit is for your door chime and onstar retention. but you will lose the date/time on the DIC. I believe the 12v constant to the DIC is fed through the radio, but the metra/scoshe harnesses eliminate it. Im sure you just have to find which pinout is for the 12c constant to the DIC and wire it up but I haven't messed with that yet. I'm just living without if for now.
  10. #9 Re: Navigation unit installed date go bye bye. HELP!!!
    Michigan
    Chats
    yeah i just found it thanks, returning the scoshe and getting the metra in there.
  11. #10 Re: Navigation unit installed date go bye bye. HELP!!!
    Michigan
    Chats
    yeah a gm/onstar harness adapter. I have that already but i guess the date still goes with the third party stereo. Oh well until a simple fix comes out, i'll just live with it.
  12. #11 Re: Navigation unit installed date go bye bye. HELP!!!
    SE Level Member Omen87's Avatar
    Salina, KS
    Chats
    I don't think you will ever see a fix to the calendar issue. If I'm not mistaken, the DIC uses the clock in the factory stereo to keep time for the calendar.
  13. #12 Re: Navigation unit installed date go bye bye. HELP!!!
    Grand Blanc, MI
    Chats
    Quote Originally Posted by Omen87 View Post
    Hate to bring up an old thread but hopefully it will help someone. I had the same problem a couple months ago when I installed my nav unit (date/time gone). Didn't bother me too much since I had heard that had happened to a few. But then last week I did an oil change for the first time since I installed the nav unit and I was unable to reset my oil life monitor. It monitored the life just fine, but the reset button did nothing. I changed the oil at about 30% so I had to do something before it started chiming at me to change my oil. I researched and it turns out I was given the wrong chime retention unit. I was given a GMRC-01 but what was supposed to get the GMOS-04. I believe this will fix the date/time issue as well. It just arrived yesterday and I plan on installing it this afternoon. I'll post back with if it works.
  14. #13 Re: Navigation unit installed date go bye bye. HELP!!!
    Feb 2009
    Virginia
    Chats
    4010
    GMOS-04 doesn't retain the date/time function either. sorry :/
  15. #14 Re: Navigation unit installed date go bye bye. HELP!!!
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Chats
    2345
    i have heard that you could take the factory radio out and install it in the trunk and then the dic wont go out
  16. #15 Re: Navigation unit installed date go bye bye. HELP!!!
    Feb 2009
    Virginia
    Chats
    4010
    sure can. Worth all that for a date? My 9887 has a date function already...
  17. #16 Re: Navigation unit installed date go bye bye. HELP!!!
    Apr 2015
    Philadelphia
    Chats
    I'm experiencing the same issue with the GM factory Nav, but I need to replace my Nav antenna anyway, so the radio is not getting time from the bird. Was the factory radio you removed the factory Denso Nav Radio 15263106?
  18. #17 Re: Navigation unit installed date go bye bye. HELP!!!
    Apr 2015
    Philadelphia
    Chats
    I believe you are correct. I'm experiencing the same issue with my GXP. I need to replace my Nav antenna to restore time to the radio. It kept working until the battery dies. The car was in storage for 6 months. I had installed the factory Nav (Denso 15263106) from my previous Grand Prix and added a Kenwood antenna to get it to see the bird, but that antenna has died for whatever reason. Now I cannot set the clock on the radio of the date on the DIC.
  19. #18 Re: Navigation unit installed date go bye bye. HELP!!!
    Jul 2016
    Brevard County, FL
    Chats
    Quote Originally Posted by jlagomarsino View Post
    So, why all this expense and effort to have less car than you bought? I keep asking this question, and I can never get an answer. Why is it that you people trust GM to build/source electronics that govern engine and transmission function, DoD, ABS, stability, etc., but you think they can't handle 1982 radio technology? What is the thinking there? And why do you want your car interior to be uglier?
  20. #19 Re: Navigation unit installed date go bye bye. HELP!!!
    Apr 2015
    Philadelphia
    Chats
    The Driver Information Center (DIC), don't laugh that's what its called in the owner's manual, needs a factory radio to receive time so it can increment the correct date. Since it is not receiving that heartbeat, it cannot keep the correct date. The fault state is what you are experiencing. The date does not save since it cannot be incremented correctly.
  21. #20 Re: Navigation unit installed date go bye bye. HELP!!!
    Jul 2016
    Brevard County, FL
    Chats
    This is definitely correct. I set the date in the DIC first in my car, and didn't do the clock on the stereo until the next day. The date advanced correctly the day after that.
  22. Advertisement
  1. GTP/Navigation
    By josh04GTPCompG in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2009, 01:32 PM
  2. DIC/date
    By blackheart in forum Audio, Security & Visual Electronics
    Last Post: 03-07-2009, 10:14 AM
