Thread: Key Fob programming
Results 1 to 8 of 8
  1. #1 Key Fob programming
    Dec 2013
    Enfield
    Anyone have any experience using scanners that will program new key fobs? Both my 2004 and 2008 Grand Prix's are down to one fob. I would rather not go to the dealer, a locksmith coming out to do both is an option but if there is a scanner that would do it for a couple hundred bucks I would consider that also. I already purchase new fobs for both off eBay. Any thoughts or suggestions is appreciated. Thanks
  2. #2 Re: Key Fob programming
    SE Level Member LouF's Avatar
    Oct 2011
    Ohio
    This doesn't answer your question, but I was just looking into this again just days ago, and I have settled on this as the answer...
    "2005 Pontiac Grand Prix Keyless Entry Remote Fob Smart Key Programming InstructionsThere is no manual on board procedure to program a keyless remote to this vehicle. This
    vehicle requires special equipment be connected to the vehicle to program the remote", BestKeys, Amazon.
  3. #3 Re: Key Fob programming
    Dec 2013
    Enfield
    Yes, already known but thanks for responding.
  4. #4 Re: Key Fob programming
    Oct 2011
    Ohio
    I came across this suggested item AFTER I made my own transmitter purchase (typical). Experiences are across the board, typical wrong instructions, inconsistency in the application claims, and dependent on original equipment, but several successful reviews.
    https://www.amazon.com/APDTY-24843-R.../dp/B00IKHVK5O
  5. #5 Re: Key Fob programming
    Oct 2011
    Ohio
    Rottonj, Check out my find on key fob programming (above).
    2005 Grand Prix GTP
  6. #6 Re: Key Fob programming
    Dec 2013
    Enfield
    I stopped by a local shop in town, the owner is a friend and he has a high end scanner. He was able to program one new remote, but was unable to do them all(lose the old when the new is programmed) . He is going to look into it. Should be able to do all, probably just a step we are missing. He was busy the day I stopped by, at least for now my remote is new with no cracked case.I will post back when I get it resolved
  7. #7 Re: Key Fob programming
    Dec 2013
    Enfield
    This is not compatible with my car as I have factory remote start, but thank you.
  8. #8 Re: Key Fob programming
    Oct 2011
    Ohio
    I've read ..."program them during the same programming cycle" and i.e. press the transmitter buttons, etc...
    BTW, they have one with remote starting.
    Also, I thought I read mentioning that the programmer only has three uses - that wasn't clear.
  1. ZZP PCM and key fob programming
    By 00RedfireGT in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2018, 09:18 PM
  2. programming a key fob
    By thegraniteplanet in forum Audio, Security & Visual Electronics
    Last Post: 11-14-2016, 06:47 PM
  3. Programming a Key Fob
    By the70judge in forum Introductions/Noob Questions
    Last Post: 09-09-2016, 11:58 AM
  4. programming key fob?
    By gtp239 in forum General Tech Discussion
    Last Post: 01-31-2011, 06:24 PM
  5. PCM programming
    By tdm571 in forum General Tech Discussion
    Last Post: 12-10-2010, 09:16 AM
