Thread: ? How do i program a new key fob?
Results 1 to 15 of 15
  1. #1 ? How do i program a new key fob?
    Donating Users
    sabina,oh
    Chats
    I got a new key fob from the dealer and they wanted a $100 to program it. Ive found stuff on the web but it didnt work, or im doing it wrong.
  2. #2 Re: ? How do i program a new key fob?
    Chats
    83662
    pull the MALL programm fuse
    close all doors
    insert key, turn to ACC then OFF then back to ACC within 1 sec.
    open and close a door, a chime should be heard
    press and hold the the LOCK and UNLOCK bottuns for 14 seconds.
    remove key from ignition
    re-install MALL fuse and your done.
  3. #3 Re: ? How do i program a new key fob?
    Top Swap in Progress bigtom9492's Avatar
    Dutchess county
    Chats
    18
    x2^^
  4. #4 Re: ? How do i program a new key fob?
    GT Level Member stevenk8's Avatar
    Macomb MI
    Chats
    what happens if you have a a/m radio and you cant hear chimes how do you know then?
    2002 grand prix gt (CAI,180*tstat,MSD wires,magnaflow high flow cat,ubend delete,18in wheels,HID headlights and fog lights)
    More mods soon to come!
  5. #5 Re: ? How do i program a new key fob?
    Donating Users
    sabina,oh
    Chats
    Where is the MALL fuse under the glove box or in the engine fuse box?
  6. #6 Re: ? How do i program a new key fob?
    Chats
    83662
    glove box
  7. #7 Re: ? How do i program a new key fob?
    Donating Users
    sabina,oh
    Chats
    Thanks for the info im gonna try it in the morning
  8. #8 Re: ? How do i program a new key fob?
    Arizona
    Chats
    did not work for me
    '00 GT- nothing special
  9. #9 Re: ? How do i program a new key fob?
    Chats
    83662
    Quote Originally Posted by coreygnar View Post
    did not work for me
    really?? hmm
  10. #10 Re: ? How do i program a new key fob?
    Macomb MI
    Chats
    didnt work for me either.
  11. #11 Re: ? How do i program a new key fob?
    Chats
    83662
    More detailed, so try it again
    Remove key from from ignition
    remove the BCM PROGRAM, from the glove box fuse box, if no BCM fuse is found remove the MALL PROGRAM fuse
    close all doors
    close the lift gate
    insert key into ignition, and turn it to the ACC ( one click towards you in the car)
    leave key in for 5 then do next step
    turn key to off and back to acc with in one second
    open a door and close it, A chime SHOULD be heard when the system enters program mode
    press and hold the LOCK and UNLOCK for 14 seconds, after seconds a chime may be heard that will confirm program
    remove key
    install FUSE
  12. #12 Re: ? How do i program a new key fob?
    Arizona
    Chats
    lift gate??
  13. #13 Re: ? How do i program a new key fob?
    SE Level Member mriley's Avatar
    Jun 2010
    enfield ct
    Chats
    save the trouble and take it to the dealer, as long as they dont charge an arm and a leg its easier
  14. #14 Re: ? How do i program a new key fob?
    Jackson, Mississippi
    Chats
    Does this procedure work for an 08 grand prix?
  15. #15 Re: ? How do i program a new key fob?
    GT Level Member mainecrab's Avatar
    Feb 2008
    Chats
    Quote Originally Posted by mcdavidhome View Post
    No this process will not work on 2004 and up Grand Prix. That will require a Tech 2 or other scanner to pair the key fob. I did have a Dorman part that would perform this task along with the key fob. I may as well sell the part as it can do 4 programming sessions and I have a virtual Tech 2 now.
  1. Replacement key how to program
    By 05grandprixgt in forum Audio, Security & Visual Electronics
    Last Post: 02-02-2010, 03:05 AM
  2. Does anyone know how to program keyless remotes?
    By green/blue05GT in forum 04+ Specifics
    Last Post: 01-20-2010, 09:36 PM
  3. Procedure to program the BCM
    By darinparsons99 in forum General Tech Discussion
    Last Post: 10-26-2009, 09:30 PM
  4. can anybody help me program my pcm
    By shawn in forum PCM Tuning
    Last Post: 08-09-2008, 11:51 AM
  5. program a fob??
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 07-07-2008, 10:22 AM
