Thread: Mounting a crossover in the doors
Results 1 to 3 of 3
  1. #1 Mounting a crossover in the doors
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    While playing throwing some components i had laying around in my buick i realized that i can actually get low end out of the door speakers. While i have no desire to use them for bass, this means I can get a well rounded sound. With that in mind, i want to install some higher end components, like some focal performance series. I just have no idea where to mount the crossovers. is there any space inside the door that will work? for reference this has about the size crossover that i will be dealing with:
    Focal Performance PS 130F Expert Series 5-1/4" 2-way component speaker system at Crutchfield.com
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: Mounting a crossover in the doors
    Pennsylvania
    I know this isn’t really what you asked, but I’m not sure what kind of setup you already have. You might be better off getting an amp and using the low/high pass filters in the amp to do what you’re trying to do. The components will sound a lot better amped anyway than just using the head unit outputs. More power to the speakers is better clarity, but again I dunno what you already have set up.
    But anyway, you might be able to find space in the doors above where the speakers mount, or inside where the window glass goes, but just make sure you check for clearance with the full range of glass motion.
    Also depending on how long the leads are after the crossover, or if you wanna add wire you could probably mount the crossover under the dash and then run the wires through the weather tubing between the frame and door.
    Also also, don’t forget that if you run that crossover on the door speakers to pull low end out of it, you might end up with a bunch of bass on the 5.5’s, a bunch of treble on the tweeters, but junk for midrange where most of the music lives.
  3. #3 Re: Mounting a crossover in the doors
    Aug 2016
    S.F. Bay Area (east bay), California
    There should be plenty of room in the doors of a Regal. I just strap them down with a long nylon wire tie to any convenient place where it won't interfere with the window going up and down or the door lock.
  1. Crossover
    By DCGTP in forum Wanted To Buy - Parts
    Last Post: 06-25-2014, 10:34 PM
  2. Crossover
    By Blownl36 in forum Turbo
    Last Post: 08-17-2010, 07:08 PM
  3. Crossover and DP
    By minichopper6hp in forum Turbo
    Last Post: 02-26-2010, 04:13 PM
  4. mounting depth on doors
    By Nowak1981 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 11:59 AM
