Thread: Major overhaul need some advice
Results 1 to 2 of 2
  1. #1 Major overhaul need some advice
    Jan 2020
    MO
    Hello I just replaced my head gaskets on my 07 GXP. I had the heads sent off and done properly. I have little mechanical skills so bear with me. I'm putting everything back together and all is well so far. 1 minor snag. The throttle body has a port that I can't seem to find where or if anything attached to it. It's just underneath the brake booster line that runs from the throttle body housing to the booster Any info would be greatly appreciated. I have a picture but am new here and don't see where to attach it
  2. #2 Re: Major overhaul need some advice
    There is an insert image icon in the quick reply box when you change the font and so on.
    The only thing I can think of is that there is a the booster line and maybe an EVAP line that connect at or just after the throttle body.
  1. Replies: 9
    Last Post: 11-29-2014, 05:50 PM
  2. Audio Overhaul.. got some ?'s...
    By LS2 BLAZER in forum Audio, Security & Visual Electronics
    Last Post: 01-10-2013, 11:33 AM
  3. Major work done....now having major problem
    By L36 Killer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-14-2012, 11:14 PM
  4. overhaul
    By LogicGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2011, 06:06 AM
  5. Overhaul
    By Spartan GL in forum Brakes/Suspension/Chassis
    Last Post: 04-06-2011, 11:49 PM
