Thread: WEhat to look for before purchasing a LS4 GXP?
Results 1 to 7 of 7
  1. #1 WEhat to look for before purchasing a LS4 GXP?
    Chats
    36
    a co-workers thinking about buying a used/private grand prix gxp. he's somewhat mechanically incline (oil changes, suspension swaps etc) but doesn't know much on engine and the more detailed stuff. heres a link to the one he's planning on checking out:
    not sure why the seller put LT-4 in the title?
    2006 Pontica Grand Prix GXP LT-4/5.3 v8 - cars & trucks - by owner - vehicle automotive sale
    I told him to check the trans fluid and if he ends up getting any type of GXP to get a trans cooler, a tune, and look into eliminating the DoD and lifter change(?). what're your advise and suggestions?
  2. #2 Re: WEhat to look for before purchasing a LS4 GXP?
    Donating User
    Aug 2016
    MI
    Chats
    As long as the trans shifts good and doesn't slip, and the engine doesn't tick it should be fine. Around 150k miles is when the lifters start to go. Mine had about 160k before it started ticking real bad. Also be sure to check the motor mounts.
  3. #3 Re: WEhat to look for before purchasing a LS4 GXP?
    Kemmerer, Wyoming
    Chats
    60223
    changing the lifter's necessitates changing all the dod/afm components. you can disable the dod/afm through the tune pretty easily if you know someone that has HP Tuners.
  4. #4 Re: WEhat to look for before purchasing a LS4 GXP?
    Chats
    83662
    375hp, lulz.
    Not even close, they make 303 from the factory, headers don't add magic butterfly horsepower.
    It says clean car fax, ask for a copy. Any major service done at say a dealership or major repair shop for warranty reason or major engine/transmission repair should show up. You can gauge what was possibly done in the past with that.
    Aside for the engine/transmission the rest if basic stuff that any grand prix can have wrong with it. Broken/blown out motor mounts, control arms bushing, wheel bearings, brakes etc etc.
  5. #5 Re: WEhat to look for before purchasing a LS4 GXP?
    Chats
    36
    well I told him to pass on this deal. the seller is actually a small dealership and he doesn't know much on the history of it other than whats on car fax. apparently the trans was replaced but by some small town/local shop that currently has ~10k miles on it. unknown tune but that was what the seller/dealer was told when he bought it at auction back earlier this year.
    edit-my co-worker did find another deal, this time an 05 GXP with 43k miles on it for $5k. its on OfferUp app/website
  6. #6 Re: WEhat to look for before purchasing a LS4 GXP?
    Dec 2013
    Enfield
    Chats
    That 2006 wasn't such bad deal if the seller was negotiable. Don't think any less of a small town transmission shop, these transmissions are not rocket science and most every decent shop knows all about their short comings and the updates to factory failures. Contrary to popular belief not everyone needs a TEP transmission. If it really was replaced and has 10k you are already ahead of the game. The tranny should have never been put behind a V8, that's the real issue as this over stuffed engine compartment suffers from heat soak. The 2005 has less miles which is great but things fail with age too.
  7. #7 Re: WEhat to look for before purchasing a LS4 GXP?
    Chats
    36
    I see. well the 05 has a rebuilt title cause it was involved in an accident which explains the low miles. the search continues.
  1. Purchasing New Crest.. 04+
    By rperry435 in forum Visual/Body Modifications
    Last Post: 12-27-2012, 11:19 AM
  2. Looking into purchasing a gxp
    By sccb85 in forum General Grand Prix Discussion
    Last Post: 11-19-2012, 10:02 PM
  3. Anything specific to look for when purchasing a 97-03 gtp
    By 98BlknSlvrGTP in forum General Grand Prix Discussion
    Last Post: 10-27-2012, 11:05 AM
  4. Possibly Purchasing 03 GTP
    By Worcester90 in forum General Tech Discussion
    Last Post: 09-10-2011, 06:45 PM
  5. Need some car purchasing advice
    By noom14921992 in forum Off Topic Discussion
    Last Post: 06-16-2011, 07:37 AM
