Thread: 2008 GXP Lifter Removal and Replacement
Results 1 to 2 of 2
  1. #1 2008 GXP Lifter Removal and Replacement
    Jul 2016
    New Orleans
    Chats
    Any guides out there for replacing lifters on the back side of engine. Side closest to the firewall.
  2. #2 Re: 2008 GXP Lifter Removal and Replacement
    Chats
    83662
    Guide? Not likely but it's pretty straight forward.
    Remove the intake manifold and fuel rail, remove the rear coil packs and slide the harness out of the way. Remove the rear valve cover, then remove all the bolts for the rocker arms. You can remove the whole rocker arm rail in one piece, then remove the pushrods one by one and label them to have them go back in the same hole. Then remove the exhaust manifold bolts to the cylinder head. Remove the bolts that hold the cylinder head to the engine block and lift the head off the motor.
    Under there is the lifters and lifter trays.
    I forget on a LS4 if the power steering pump is bolted to that cylinder head or if any brackets are bolted to the head on the serp belt side.
  1. lifter replacement
    By Eric Whitter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-18-2012, 04:05 PM
  2. Lifter and LIM gasket replacement
    By plasmeh in forum General Tech Discussion
    Last Post: 05-09-2011, 10:11 PM
  3. Advice on lifter replacement
    By goldgp in forum General Tech Discussion
    Last Post: 02-12-2011, 08:51 PM
  4. Engine ticking still, After lifter replacement.
    By 02grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2011, 01:58 PM
  5. Lifter replacement
    By kfish in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2009, 05:35 PM
