Thread: Tuner purchase confusion
Results 1 to 12 of 12
  1. #1 Tuner purchase confusion
    Jul 2017
    Christiansburg,VA
    So is the u7191 tuner the correct predator tuner to buy? Will it firm up the shifts on my 06 gxp? I have researched this but not a lot of info on this tuner these days.
  2. #2 Re: Tuner purchase confusion
    If want to waste your money, yes buy that programmer.
    I googled it and it says you can't even buy that unit, not even on summit racing.
    The only tuners to consider buying a HP Tuners or EFI live. Those are the only 2 real tuners that can actually tune the vehicle to your desired needs. Anything else is just a "flash programmer" that has basic built in calibrations and that's not the way to tune a LS V8.
    After owning HP Tuners for 5+ years, it is a superior product compared to Edge/HyperTech, Diablo.
  3. #3 Re: Tuner purchase confusion
    Jul 2017
    Christiansburg,VA
    That’s a lot of money to just disable dod.
  4. #4 Re: Tuner purchase confusion
    If that is all you want you are better off paying someone to tune it.
    HP Tuners or EFI Live are real tuning software that can change any parameter inside the computer to fully tune the vehicle. That was my suggestion if want to fully optimize the engine/transmission tuning.
    Or buy this.
    https://www.amazon.com/Range-Technol.../dp/B00BR1R8N8
  5. #5 Re: Tuner purchase confusion
    Jul 2017
    Christiansburg,VA
    If that will work on my 06, that’s exactly what I’m looking for!
    Thanks!!!
  6. #6 Re: Tuner purchase confusion
    Jul 2017
    Christiansburg,VA
    Or buy this.
    Before I break down and buy range technology, I have to ask. I've got a guy locally that has HP tuners but he doesn't know much about how to use it. Any way you could tell what I'd need to do to use his HP tuner software? He bought it for his truck. Would I need to buy anything else but vehicle credits? Provided I knew what I was doing in the software. I am pretty software savvy.
    I simply want to disable dod and firm up shifts on trans to hopefully get more life out of it. Is it worth buying HP tuner credits or just buy the range device?
    I won't be doing performance mods. Most if not all mods will be longevity mods since it's got 160k on it. Thanks for the help!
  7. #7 Re: Tuner purchase confusion
    just the hp tuners hardware/software loaded on the laptop and credit to unlock the particular VIN to license and from there start tuning. if al you're doing is deleting the DOD function and firming up the shifts, just borrow it and if you need to ask and borrow it again lol.
  8. #8 Re: Tuner purchase confusion
    Yup, you'd just need to install the software onto your laptop or use his laptop if it's already installed. Make sure you are using the most up to date 3.6 software from his customer page on HP Tuners to prevent any issues.
    Then buy 2 GM credits or if he already has GM credits, give him $100 for the credits and read/license your VIN/file. Then it's as simple as finding the DoD/AFM enable/disable drop down and setting it to disable and do whatever else you want.
  9. #9 Re: Tuner purchase confusion
    Jul 2017
    Christiansburg,VA
    Ok. So would the firming up of the shifts be easy to program too?
  10. #10 Re: Tuner purchase confusion
    Yes, it's only a few tables to mess with to increase shift time and add 10-15% line pressure.
  11. #11 Re: Tuner purchase confusion
    Jul 2017
    Christiansburg,VA
    Great. Thanks for the help!
  12. #12 Re: Tuner purchase confusion
    you can download sample tunes from other people found on the hp tuners bin repository and use it as a comparison to get an idea on how much to increase it by. just make sure to find one that matches your car's engine/trans. cant recall the link to it but if you go on ls1tech forum and go under their pcm and tuning section theres a sticky to get there.
  1. Coolant/Confusion
    By gfp641 in forum Introductions/Noob Questions
    Last Post: 07-14-2016, 08:01 PM
  2. PCV confusion.. Why are there 2 ports??
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 04-22-2016, 10:40 PM
  3. Confusion about Downpipes
    By SomeDudeAtHome in forum General Tech Discussion
    Last Post: 11-25-2009, 11:59 AM
  4. exhaust confusion
    By M.$tErNeR in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2008, 09:15 AM
