Thread: Dipstick Tube Is Stuck... Am I Missing Something?....
Results 1 to 7 of 7
  1. #1 Dipstick Tube Is Stuck... Am I Missing Something?....
    SE Level Member Badgers4life's Avatar
    Mar 2013
    Taking off the dipstick tube and it is stuck. mounting bracket was removed and it will not budge no matter how much force I muster.. I'm hoping I'm missing something...
    08 GP - GXP 5.3L V8
    Mods: Hayden Tranny Cooler, Transgo Shift Kit, Wix In-Line Tranny Filter, Taylor Pro 10.4mm Wires, NGK Iridium TR6IX Spark Plugs, and more to come..
  2. #2 Re: Dipstick Tube Is Stuck... Am I Missing Something?....
    Oct 2011
    Toledo, OH
    On the GTP it's just held on with one bolt on the block and an o-ring at the pan. It's in there pretty good though. Hit the pan end with some PB blaster and give it a twist.
    May be different on the GXP.
    7"
  3. #3 Re: Dipstick Tube Is Stuck... Am I Missing Something?....
    Mar 2013
    It's definitely just the one bolt. I'm going to cut it in half so I can at least take the exhaust manifold off (was going to do this anyway) and thread in a bolt and try to twist it out... It's really stuck in there.
    08 GP - GXP 5.3L V8
  4. #4 Re: Dipstick Tube Is Stuck... Am I Missing Something?....
    There is a o-ring on the tube in the middle and that along with it being about 1in longer past the o-ring and slightly curved going into the block is why they are hard to remove. For sure if they have never been removed before.
    I would spray some lube/pb blaster down there by the entry point and see if you can see the lip on the bottom of the diptstick. Sometimes you can get a little flat blade screw driver in there to help pry it up.
  5. #5 Re: Dipstick Tube Is Stuck... Am I Missing Something?....
    Mar 2013
    I'll give that a shot first. It looks like it has scooted upwards a little bit so I may be able to get a screwdriver in there. Thanks for the tips!
    Changing my coolant turned into a disaster with a crack radiator. It must have been pretty brittle but it has been new issue after new issue since..
    08 GP - GXP 5.3L V8
  6. #6 Re: Dipstick Tube Is Stuck... Am I Missing Something?....
    Arizona
    Run the car for 10 min take out the 15mm bolt and gently twist left to right while pulling. Pull the oil fill off as well.
  7. #7 Re: Dipstick Tube Is Stuck... Am I Missing Something?....
    Mar 2013
    I was able to get it out... I initially was able to pull out the dip stick tube, or so I thought. I later learned that the 3 inch end of the tube was still stuck in the block, flush to the block. At this point hope was given up and I thought I was done for.. But, after some digging I learned it still could be saved.
    I soaked the remaining portion/block entry point in WD40 and Seafoam for 2 nights. Then I used different sized lag bolts to thread into the remaining piece. After 2 hours of knuckle smashing, lots of profanity, and a little muscle, it eventually came out and saved me from having to remove the motor.. hallelujah
    08 GP - GXP 5.3L V8
  1. Transmission dipstick tube disconnected.
    By aequitasmurphy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2017, 12:20 AM
  2. Oil dipstick tube
    By chevyy1212 in forum General Tech Discussion
    Last Post: 08-26-2011, 09:46 AM
  3. HELP! Little piece of dipstick fell into oil tube/reservoir
    By Noopsky13 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-26-2011, 07:19 PM
  4. Modified Trans Dipstick tube from Intense...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 02-22-2008, 07:54 PM
