Thread: Possible TCM Issue?
Results 1 to 4 of 4
  1. #1 Possible TCM Issue?
    Aug 2017
    Midwest
    I have a stock 08 GXP with 66,000 miles. After changing batteries out, the speedometer would jump erratically. Shortly after that, while coming to a stop, the car will stall at idle. It almost seems as if it's not downshifting or the torque converter isn't disengaging.
    I had the TCM flashed and reprogrammed. That fixed the issue for about 5 days, then it picked up where it left off. Mechanic is wanting to install a new one to see if that fixes the issue.
    Has anyone had this issue before? There are no codes or lights being displayed either.
  2. #2 Re: Possible TCM Issue?
    May 2017
    Dirtyzville, Mizzery
    I had that issue; not saying that is the same thing....but I actually had a mechanical failure. Car would bog and jump and act all sorts of dumb. Sometimes totally die. Completely at random. Ended up being a failed Torque Converter from extended amounts of heat from the LS4 that killed it. Hopefully that isn't your case...but my trans kicked the bucket at 62k. I also had no visible codes or anything of that nature.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  3. #3 Re: Possible TCM Issue?
    Arizona
    If I were u I'd double check the grounds and the tighten the fusblock connectors, since that's where your problem started.
    I would also highly reccomend getting a real tune. Replacing the TCM will help nothing .
  4. #4 Re: Possible TCM Issue?
    GT Level Member Gregorius's Avatar
    Davenport, IA
    I'm with 91PA. Someone tugged on cables swapping the battery in, first thing I'd check is that ground connection 10mm bolt 1 ft in front of the battery on top of the radiator support.
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  1. led headlights issue / fog issue
    By Jdiding in forum Visual/Body Modifications
    Last Post: 12-13-2016, 10:01 AM
  2. Weird speedometer issue, possible trans issue?
    By Peder in forum General Tech Discussion
    Last Post: 07-28-2014, 07:08 PM
  3. Issue with A/C no more cold air and sound issue with Shocks
    By ibra0078 in forum General Grand Prix Discussion
    Last Post: 08-09-2013, 08:25 AM
  4. Wheel Bearing Issue or Tire Issue
    By ibra0078 in forum Tires & Wheels
    Last Post: 06-07-2013, 05:12 AM
  5. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
