Thread: Running lean on bank 1
Results 1 to 13 of 13
  1. #1 Running lean on bank 1
    Mar 2015
    Sierra Vista, AZ
    So I have tried to find a cure for this and right now I feel like I am just throwing parts at the car. I am getting a P0171 Fuel Trim System Lean Bank 1 code on and off again.
    So far I have replaced the stock injectors with rebuilt flowmatched ones from ZZP. I have changed the fuel filter. I have changed the fuel regulator. I have changed the two fuel pump relays. I have bent the one pin on the outer relay out to make the pump stay in "high" mode. I have changed the MAF. I have changed the MAP. I have replaced all of the vacuum line with new rubber line. I have tested the fuel pressure. It is 41-42 normal and with the vacuum line from the fuel pressure regulator pulled it goes up to a steady 50.
    The code is intermittent and usually only comes on when the car is coasting, at idle or bearly above idle. When I'm pressing on the gas more than a little bit, then it doesn't come on. Yeah, I know. Just keep it to the floor, but seriously I need help fixing this. I have a new AC Delco pump coming to me and a high flow fuel filter on the way also, just in case.
    Any knowledge, thoughts, or enlightenments would be greatly appreciated.
    For the sake of getting help, I have a 99 GTP 3.8 Supercharged stock.
    Thanks again in advance.
  2. #2 Re: Running lean on bank 1
    May 2012
    Where winter never ends
    How are your O2 sensors, sounds like your front O2 is bad... You replaced a lot of stuff lol
    2000 Regal - Winter Beater
  3. #3 Re: Running lean on bank 1
    At this point I would be doing a smoke test.
    Could be a crack in the EGR tube, could be a leak between the TB and supercharger. Hard to say when we are just guessing and you are tossing parts at it.
    I would be watching fuel trims on a scanner and either spraying carb cleaner or brake cleaner around anywhere that can suck in extra air past the MAF sensor. Watching for a change in the numbers, only nice data logging scanners will pick up the minor changes as they have fast refresh rates.
  4. #4 Re: Running lean on bank 1
    May 2012
    But hey if you wanna toss more parts im putting money on O2s, or you could do it the right way and start checking like ^^ said.
  5. #5 Re: Running lean on bank 1
    Mar 2015
    Sierra Vista, AZ
    If things go over my head, then I apologize for my ignorance as I am not a mechanic, but I am trying to pour my love of my car into fixing it. I am not sure what a smoke test is. I assume it has to do with trying to find a vacuum leak? While replacing the vacuum lines I did a recommended check of spraying WD40 and seeing if the car changes how it runs. This is the check that lead me to find a bunch of cracked lines. I replaced them and now the test doesn't reveal any more leaks. How does this smoke test work?
    I replaced the paper gasket between the throttle body and the super charger with the rubber one from ZZP performance. I retightened it after you said it. It is very tight still.
    As for scanners, what type of scanner are you talking about and where can I get one. Right now I just have a code scanner that tells me the code and resets the CES light. I am more than happy to get good tools to trouble shoot. I just need to know exactly what is needed so I get the right one.
    Thanks again for the quick replies.
  6. #6 Re: Running lean on bank 1
    Mar 2015
    Sierra Vista, AZ
    Oh, and where is the EGR tube so I can check it?
  7. #7 Re: Running lean on bank 1
    Apr 2015
    Columbus, OH
    The egr tube goes into lower intake just below the throttle body. Its a metal flex tube that's known to crack. Check out torque pro app for Android if you want something cheap to scan with. You need a Bluetooth obd II adapter. There is a ton of info around about it and which BT adapter to buy. This will allow you to monitor fuel trims and can help find a vac leak. Helped me find one on my sienna and netted me 4mpg after I fixed the leak
    If your code is coming on shortly after you reset it, I'd say you have a decent sized vac leak. It took me about 4 cans of carb cleaner before I found my leak. I had to spray it in just the right spot/angle to make it register. Could be something you overlooked like o-ring on dipstick or oil filler neck.
  8. #8 Re: Running lean on bank 1
    For a lot of great info...without me having to repost it. Please search on P0171 and my username.
  9. #9 Re: Running lean on bank 1
    Mar 2015
    Sierra Vista, AZ
    Bill, I did what you said, but it only returned 19 results with most stating you were a great help when they read what you posted, but I couldn't see the older posts for some reason. I did see that I should clean off the battery terminals and check the EGR tube. Is the EGR tube easy to replace or even get?
  10. #10 Re: Running lean on bank 1
    Bummer
    I've posted quite a bit as I fought this code a lot.
    Can be MAF
    TB gasket
    EGR tube, you have to pull it to check it. Do not trust spraying carb cleaner at it. I have seen a bad tube test good with this method.
    Battery cables like you mentioned
    Even a bad ground at the transmission stud.
  11. #11 Re: Running lean on bank 1
    GT Level Member dezebe1's Avatar
    May 2013
    Dallas TX
    One overlooked item people miss is the BBV or boost bypass valve. If you spray carb cleaner up into where the rod actuates you might find the diaphragm could be the cause, you would see you fuel trim readings change when you spray at the base of it.
    Team JB-Weld
  12. #12 Re: Running lean on bank 1
    Mar 2015
    Sierra Vista, AZ
    Thanks, brother, I will check those. Are those tubes an item that can be picked up at a parts store, or do I have to junk yard hunt?
  13. #13 Re: Running lean on bank 1
    jY or dealer
  1. P0171 Front Bank Lean
    By Wolf79 in forum General Tech Discussion
    Last Post: 05-15-2014, 12:50 AM
  2. Codes P0171 Lean Bank One
    By Garry in forum General Tech Discussion
    Last Post: 02-07-2013, 05:10 PM
  3. #4 misfire during boost, also bank 1 lean
    By petebjork in forum Introductions/Noob Questions
    Last Post: 06-01-2012, 11:44 PM
  4. P0171 - System Too Lean (Bank 1)
    By siege101 in forum General Tech Discussion
    Last Post: 04-28-2012, 07:48 PM
  5. Running lean in one bank?
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2010, 01:22 PM
