Thread: Hard starting after sitting for days.
Results 1 to 12 of 12
  1. #1 Hard starting after sitting for days.
    Slower, Lower Delaware
    Since I put on my IC I have to turn over the car several times before it will start. Except for that everything is perfect. It only happens when it sits for a few days. Any ideas why?
  2. #2 Re: Hard starting after sitting for days.
    Maybe a vacuum leak?
  3. #3 Re: Hard starting after sitting for days.
    Willoughby, Ohio
    I too was going to say vacuum leak....
  4. #4 Re: Hard starting after sitting for days.
    Quote Originally Posted by CTKGP09 View Post
    Only after sitting more than 2 days and no trace of it except at startup?
  5. #5 Re: Hard starting after sitting for days.
    Vaccuum leak or by any chance have you checked your fuel pressure?
    04 Comp G.
  6. #6 Re: Hard starting after sitting for days.
    Haven't checked the fuel pressure. Think it may be leaking down after sitting? I was thinking about putting a gauge on the new ZZP fuel rails.
  7. #7 Re: Hard starting after sitting for days.
    Could be.. I know if my GP is sitting for a few days it takes a few cranks to get it started.
    04 Comp G.
  8. #8 Re: Hard starting after sitting for days.
    Aug 2013
    McDonald PA
    Mine sat for a week and a half. Started perfectly fine
  9. #9 Re: Hard starting after sitting for days.
    Congrats?
    04 Comp G.
  10. #10 Re: Hard starting after sitting for days.
    Mind sits for two days it doesn't start on first time, usually on the second. This time it sat for 12 days and took several tries to get it going. This action started after I put the I/C on with the 3.4 pulley.
  11. #11 Re: Hard starting after sitting for days.
    I wouldn't necessarily say it's the IC causing the issue could just be a coincidence..
    04 Comp G.
  12. #12 Re: Hard starting after sitting for days.
    Possibly, there was a lot done when the I/C when on, fuel rail, etc.
  1. hard time starting
    By kawasakidrivinghick in forum General Tech Discussion
    Last Post: 01-29-2013, 05:04 PM
  2. E85 hard start in mornings or after sitting a while
    By LapeerGTP in forum PCM Tuning
    Last Post: 08-06-2012, 11:28 AM
  3. hard starting
    By BlackGT97 in forum General Tech Discussion
    Last Post: 12-17-2011, 08:14 PM
  4. hard starting
    By Moriarity81 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2011, 11:56 PM
  5. Help Car Hard Starting
    By rstark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2008, 06:24 PM
