Thread: Looking for a good kit/list of parts for lower intake manifold gasket replacement
Results 1 to 15 of 15
  1. #1 Looking for a good kit/list of parts for lower intake manifold gasket replacement
    Jan 2014
    Woodstock, GA
    Hi,
    Can anyone tell me if this is a good and comphrensive set of parts to do a LIM gasket replacement? Too much, too little, just right?
    http://www.ebay.com/itm/97-03-GM-380...74fb39&vxp=mtr
  2. #2 Re: Looking for a good kit/list of parts for lower intake manifold gasket replacement
    Totally overkill!
    Hang right I'll get you a part #
    04 Comp G.
  3. #3 Re: Looking for a good kit/list of parts for lower intake manifold gasket replacement
    depending on the year car you have lim gaskets job can be done for a bout a 100 bucks in total, with fluids and new oil and filter.
  4. #4 Re: Looking for a good kit/list of parts for lower intake manifold gasket replacement
    Less then that if you use coupon codes like u always preach!
    04 Comp G.
  5. #5 Re: Looking for a good kit/list of parts for lower intake manifold gasket replacement
    Feb 2009
    flintnasty MI
    Lim and sc gasket should be all you need
  6. #6 Looking for a good kit/list of parts for lower intake manifold gasket replace...
    Lim gasket
    Aluminum elbows
    Sc gasket
    Oil, coolant, a little rtv
    And knock out the vc gaskets if you need to while your there
    04 Comp G.
  7. #7 Re: Looking for a good kit/list of parts for lower intake manifold gasket replacement
    Jan 2014
    Woodstock, GA
    Cool, thanks - now I'm glad I asked! Part #s would be great (I am assuming Rockauto but will buy from anywhere recommended) and I'm good at tracking down coupons!
    Sorry about forgetting the year - it's a 2003 GTP
  8. #8 Re: Looking for a good kit/list of parts for lower intake manifold gasket replacement
    if you got advance auto near buy buy on line, us discount code, pick up local. enter your car in the search and your parts will come up. you can then take that part # and google it. amazon also has good prices.
  9. #9 Re: Looking for a good kit/list of parts for lower intake manifold gasket replacement
    Jan 2014
    Woodstock, GA
    OK, here is what I put together + oil and coolant. Looks good?
    Felpro Intake Manifold Gasket Set
    Part No: MS 98014 T
    Felpro Valve Cover Gasket Set
    Part No: VS 50465 R
    Dorman - Help Heater Hose Elbow Aluminum
    Part No: 47065HP
    Felpro Plenum Gasket Set
    Part No: MS 95744
  10. #10 Re: Looking for a good kit/list of parts for lower intake manifold gasket replacement
    you'll also want to pick up some vac line and new T's they are gonna break.
    if your lim gaskets dont come with a small tube of rtv pick one up. its for the corners under the lim.
  11. #11 Re: Looking for a good kit/list of parts for lower intake manifold gasket replacement
    Jan 2014
    Woodstock, GA
    Got it, what about the upper intake gasket set? Not needed or replace if needed once I'm in there?
  12. #12 Re: Looking for a good kit/list of parts for lower intake manifold gasket replacement
    gen 3 you need a need gasket for the sc/upper plenum. your also gonna need some way of scrapping off the old sc gasket, it glues its self around the coolant ports area. i used razor blades and sand paper and brake cleaner to get it all off. took maybe a 1/2 hour to clean the lim and sc up real good.
  13. #13 Re: Looking for a good kit/list of parts for lower intake manifold gasket replacement
    Jan 2014
    Woodstock, GA
    So I'm pretty far into the LIM replacement and starting to put things back together.
    In the Fel-Pro LIM kit there are two bags of O-rings. Each has 6 rings in it. The small rings are obviously for the injectors. What about the slightly larger rings? I expected enough rings to do the bottom and top of the injector but the larger rings fit pretty loosely. I must be missing something? Let me know if I need pics to help provide answers.
  14. #14 Re: Looking for a good kit/list of parts for lower intake manifold gasket replacement
    The 2 yellow orings go around the coolant ports.
  15. #15 Re: Looking for a good kit/list of parts for lower intake manifold gasket replacement
    Jan 2014
    Woodstock, GA
    I figured out that the larger black o-rings were for the L36 injectors. I need an extra pack of 6 to swap out all 12 on the injectors.
    Slick2500, you read my mind for my next post. I needed an accurate pic showing the bolts for the LIM. The service manual doesn't show them well and is missing #5. Thanks! And I got the yellow o-rings in place.
  1. Replies: 65
    Last Post: 09-11-2014, 09:52 AM
  2. tips/tricks. list for upper/lower intake manifold gasket job..
    By crod in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-30-2012, 12:51 AM
  3. Intake Manifold Gasket Parts List
    By Burbman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2012, 03:35 PM
  4. Where to get the good parts for a intake gasket replacement?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2012, 03:44 PM
  5. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
