Thread: Do you need a double roller timing chain with 105# valve springs?
Results 1 to 10 of 10
  1. #1 Do you need a double roller timing chain with 105# valve springs?
    Jun 2012
    Southern NJ
    Chats
    Need a quick answer, thanks in advance.
  2. #2 Re: Do you need a double roller timing chain with 105# valve springs?
    Chats
    77762
    Can you?
    Yes.
    Do you need to?
    Not with 105's.
    Quick answer for a kinda vague situation...factory cam or rockers as well?
  3. #3 Re: Do you need a double roller timing chain with 105# valve springs?
    Jun 2012
    Southern NJ
    Chats
    Quote Originally Posted by blueguy91 View Post
    Can you?
    Yes.
    Do you need to?
    Not with 105's.
    S1X cam with new JP single roller chain.
  4. #4 Re: Do you need a double roller timing chain with 105# valve springs?
    Chats
    77762
    I ran an XP with LS6's on a new stock chain and dampner.
    It's not required.
  5. #5 Re: Do you need a double roller timing chain with 105# valve springs?
    Jun 2012
    Southern NJ
    Chats
    Good. I was about to have a massive coronary. Thanks a bunch.
  6. #6 Re: Do you need a double roller timing chain with 105# valve springs?
    Chats
    77762
    Dave @ TEP had 130's with a stock chain/dampner and whatever cam he was runnin if that makes you feel any better about it, ha.
  7. #7 Re: Do you need a double roller timing chain with 105# valve springs?
    GTP Level Member
    Sep 2011
    Motown
    Chats
    921
    So your saying my topswap setup with a xp cam and #105s will work just fine with my stock timing chain/dampner. My timing chain/dampner have 90k on them.
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  8. #8 Re: Do you need a double roller timing chain with 105# valve springs?
    Ohio
    Chats
    23141
    no replace them with a new stock chain set
  9. #9 Re: Do you need a double roller timing chain with 105# valve springs?
    GTP Level Member
    Sep 2011
    Motown
    Chats
    921
    will it be reliable if not driven with ease all the time?
  10. #10 Re: Do you need a double roller timing chain with 105# valve springs?
    Ohio
    Chats
    23141
    yeah itll be fine
  1. help me with a double roller timing chain
    By foursixer in forum General Tech Discussion
    Last Post: 12-20-2010, 12:20 PM
