Thread: Maxing out stock injectors? but don't think i should be.....
Results 1 to 7 of 7
  1. #1 Maxing out stock injectors? but don't think i should be.....
    hey i have a 2007 grand prix gt with s1x, cam, oer lifters yella terra rockers, 105 springs and modded retainers, 3.5 pulley, headers 3" down pipe, plugs and t stat and intake ect, and hp tuners and well at about 5100 rpm i reach 100% injectors duty and 23ms pulse all the way to about 136% and 25-26ms at about 6000-6400 rpm. with about 6kr at the 5100+ range. so what i wana know is do i need new injectors or should i start looking at fuel pump and its gay filter in the tank for the 07 if new injectors what should i got with i plan on doing more mods down the road. thanks.
  2. #2 Re: Maxing out stock injectors? but don't think i should be.....
    Jul 2010
    Houston, Texas, United States
    Quote Originally Posted by blackgrandprix View Post
    42# injectors are what most of us do as our first injector upgrade. Did you do the fp rewire? Injector size would depend on your future plans for your car bro.
  3. #3 Re: Maxing out stock injectors? but don't think i should be.....
    GT Level Member 04boostedindyss's Avatar
    May 2011
    boynton beach florida
    im surprised you shouldnt be running out of injector yet...what are your other mods..and if you dont have a furl pump rewire, i recomend one from racetronix...
    E85, Gen V, Xp, Supporting mods, crap tune!
  4. #4 Re: Maxing out stock injectors? but don't think i should be.....
    Pennsylvania
    Maxing injectors on only a 3.5? shouldn't max until somewhere in the 3.0-3.2 range on 93 octane, right?
  5. #5 Re: Maxing out stock injectors? but don't think i should be.....
    94 oct yes
  6. #6 Re: Maxing out stock injectors? but don't think i should be.....
    GTX Level Member crbquist's Avatar
    Massachusetts
    Keep in mind he also has a gen V. You will max out stock injectors below a 3.1 on a gen 3. On a gen 5 I believe you will max them at a 3.3 - 3.4 depending on the setup.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  7. #7 Re: Maxing out stock injectors? but don't think i should be.....
    depends on your tune and how much fuel you need to dump to quelch the knock for your pulley that is or is not too small.
  1. stock injectors
    By Sundance 6g72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2011, 07:56 AM
