Thread: Burning??
Results 1 to 13 of 13
  1. #1 Burning??
    Texas
    Hey there all, When I go to start my car and when it starts to warm up there is smoke coming from the back of the engine. I have a water leak some where, not sure. Are there freeze plugs back there that can be letting out water hitting the exhaust causing the smoke? Or can it be the valve cover leaking oil and burning it off? I have a slight oil leak not to bad though.
  2. #2 Re: Burning??
    Largo, Florida, United States
    rear main seal.
  3. #3 Re: Burning??
    rear main seal.
    Right. Because the real main seal is towards the back of the engine bay, not by the bell housing.
    A nice test I like to do is clean everything really well then drive it until you can see where it starts smoking again and check where the leak is coming from. Coolant smells nasty when it burns IMO. I'd check the valve covers and the LIM gaskets...could be leaking both coolant AND oil if they have been neglected...just my 2 cents.
  4. #4 Re: Burning??
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    rear main seal.
    you hit the nail on the head there
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  5. #5 Re: Burning??
    Charles City, IA
    I say valve cover gaskets. Not much that will leak coolant on to your rear mani. You could do intake gaskets they are probably leaking also.
    SMGPFC Two Nipple General
  6. #6 Re: Burning??
    Naperville illinois
    Yea, if it's burning i doubt it'll make it from the main seal... sounds like vc gaskets have told you they no longer enjoy sealing.
  7. #7 Re: Burning??
    Dec 2008
    London, Ontario
    if you're doing valve cover gaskets might as well do intake gaskets while you're working on it, its not too much more work
  8. #8 Re: Burning??
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    bad rear main seals leak water?
    learn something new every day.
  9. #9 Re: Burning??
    Texas
    Thanks for the advice, I have been wanting to change the VC gasket and from what I read on here the lim gasket seems to go bad to so think I might as well change them all. So are there any freeze plugs on the engine side where the spark plugs are at?
  10. #10 Re: Burning??
    Charles City, IA
    no.
  11. #11 Re: Burning??
    There are 2 freeze plugs on the ack of the block under the head abovethe knock sensor. The rears would be a bear to do with the engine in the car I imagine.
  12. #12 Re: Burning??
    Charles City, IA
    Those would not leak on the mani tho, unless you flipped the car, then you have more to worry about.
  13. #13 Re: Burning??
    Right...but leaking coolant on a hot block would probably do the trick too.
  1. burning antifreeze
    By gearjammer79 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-02-2009, 01:29 PM
  2. Gas Burning QUICK!
    By ThePrixGt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2009, 08:09 PM
  3. Burning oil, misfire #2
    By Blackbeauty01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2009, 03:43 PM
  4. burning smell
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 09:42 AM
  5. Thats it, Im burning the ***** down
    By Toofastgs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2008, 08:52 AM
