Thread: Bad lifters?
Results 1 to 5 of 5
  1. #1 Bad lifters?
    SE Level Member rah575554eg's Avatar
    Apr 2009
    Alliance, NE
    I have been getting KR on my grand prix for a while now not to much but its still there. The mods I have on the motor is a 3.5" pulley, 2.5" catted downpipe, K&N air intake, 180* stat, Overkill pcm and I had switched the plugs to a TR8 super cold plugs to try getting rid of the KR but still has some on the highway. I was wondering since there is a little bit of noise coming from the lifters I think but could that cause KR? I have noticed that when on the highway at cruising speed the bogging down will kick in then when starting up a hill the rpms will bounce then climb with the accleration and that when I see KR. I also think there might be a vacuum or intake leak but not sure. Any help would be great because no one in my area does scanning or tuning. Thanks!
  2. #2 Re: Bad lifters?
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    gps stock has kr..your always gona have kr with a overkil pcm ur best bet is to get a tune from sum1
  3. #3 Re: Bad lifters?
    swift current,sask.
    Or get rid of the 3.5...
  4. #4 Re: Bad lifters?
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    X2 ^^ i think u should just put stock pulley back on until u get enough supporting mods. have u read the safely modding your 3800 thread?
    If u havent u need to read that
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  5. #5 Re: Bad lifters?
    technically he should be good as is with a good tune, but telling that to everyone will have people pulley happy.
  1. Which lifters to buy?
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-01-2010, 06:17 PM
  2. L36 Lifters vs L26 Lifters
    By Bedwards in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-05-2010, 11:27 AM
  3. Bad Lifters?
    By BDEGhost in forum General Tech Discussion
    Last Post: 11-04-2009, 07:46 PM
  4. where to get Ls7 lifters???
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2009, 01:05 PM
  5. Lifters
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:46 AM
