Thread: XPZ Cam People Step In. Help Please!
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: XPZ Cam People Step In. Help Please!
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    **** Turbo Tim...and that Eric guy IIRC.
    All a bunch of egofilled used tampons.
    HAHA. Dude u always say the funniest sh!t.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #22 Re: XPZ Cam People Step In. Help Please!
    Donating Users kfish's Avatar
    Ohio
    Quote Originally Posted by bbptech View Post
    Ya, that they are. I wont do anymore business with them unless i have to. I wonder how intense will do with the new owner John Rucker? I might talk to Zooom about Turbo B!tch and how much of an ass he is but it might just be a waste.
    waste. people will continue to do business with them. they are good at what they do, ill give them that. I went up when my car wouldnt run, thinking it was their pcm, but it turned out that the crank/cam sensor harness has rubbing the balancer causing a short to ground, they figured it out right away but still charged me 2 hours labor at $100 an hour. Then an additional 1 hour of dyno time for 2 ****ing pulls, until they realized that my cat was clogged. Then tim had the balls to bring me out a set of zzp headers and say hed install them and everything for $1000, I politely laughed and told him i had SSAC's on the way for a 1/3 of that price.
  3. #23 Re: XPZ Cam People Step In. Help Please!
    ya thats what shawn said was wrong with your car. But thats ****ing ****ty how they charged that much. haha the ones he brought out were probably mine that he had sitting right at the door.
  4. #24 Re: XPZ Cam People Step In. Help Please!
    Well hopefully when it gets started a second time it doesnt do it. Ya i should have got the LS7's but if i set the preload right i shouldnt have a problem with them.
    They won't stop...they are always loud and annoying...thats why I tell everyone not to buy them.
    Haha. Didnt realize that it said Retile up until u said something. lol. Thanks. And ya hopefully everything gets figured out.
    I pointed that out to you a few months ago noobsauce. *smacks forehead*
    Not really...just calling it how it is there.
  5. #25 Re: XPZ Cam People Step In. Help Please!
    Ohio
    probably. that was before tim tried telling me that top swaps were pointless and their ssm90 kit was so much better. HA. See why i stick with intense?
  6. #26 Re: XPZ Cam People Step In. Help Please!
    Quote Originally Posted by kfish View Post
    It is better...
  7. #27 Re: XPZ Cam People Step In. Help Please!
    Haha well i dont remember blue. i smoke myself stupid so i always forget ****. lol
  8. #28 Re: XPZ Cam People Step In. Help Please!
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    What rocker arms are you using with this build? Since you are using the Comp OE-R lifters they are going to tick a bit and are much more sensative than the stock lifters to preload, so a little loose or a little tight and they will make excessive noise and can trigger false KR at low rpms while driving around so you will definatly want to keep an eye on that. You are correct that they shouldnt have as much preload and 1/4 to 3/4 turn is where you want to be at.
    As far as the tick being from the headers that is highly possible if you dont have a good seal. I use OE GM steel gaskets on everything and spray copper spray on the header side and it works great. The felpro gaskets work very well also at sealing up problem areas as well.
  9. #29 Re: XPZ Cam People Step In. Help Please!
    Banned - Busted For Scamming
    Feb 2009
    Ive never had any problems using felpros.
  10. #30 Re: XPZ Cam People Step In. Help Please!
    me either.
  11. #31 Re: XPZ Cam People Step In. Help Please!
    how can i measure the preload of the lifter so i can rule out the possibility u stated trannyman?
  1. Next Step?
    By Bunique7 in forum General Tech Discussion
    Last Post: 08-13-2009, 10:09 PM
  2. Step Up
    By Sharkey in forum Off Topic Discussion
    Last Post: 04-06-2009, 03:03 PM
  3. BlackJack people, step in (AT&T)
    By 3800SE in forum Off Topic Discussion
    Last Post: 05-29-2008, 11:19 AM
  4. Step by Step header install.. HELP!!!
    By Mikegotone'02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2008, 01:51 PM
  5. L26 Guys....Step on in.
    By Reptile in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2008, 07:50 AM
