Thread: Putting Motor In
Results 1 to 20 of 26
  1. #1 Putting Motor In
    Addison, Mi
    Does anyone know what it takes to put the motor back into the car. What tools and all that good stuff. Step by Step so i only have to do this once .
    Thanks Guys
  2. #2 Re: Putting Motor In
    Donating Users kfish's Avatar
    Ohio
    basic hand tools. leave the ac compressor off but lay it on the engine cradle, i always laeve the alt and bracket off too. drop it in. 13mm on the power steering pump, 13mm on alt bracker and alt, 15mm on lower engine mount, 18mm on converter bolts, 18mm on bellhousing bolts, 15mm on ac compressor, 15 mm on starter. 13mm on the b terminal on the starter, 8mm on the s terminal. 10mm for the dust sheild that goes around the converter. 13mm on the downpipe. 13 mm on trans to engine block bracket. plug in all your sensors, maf, tps, iat, oil level sensor, oil sending unit, knock sensors, etc. put the cross over on, 13mm. put the belt on double check EVERTHING. change the oil and hook the negative battery cable back up. start it
  3. #3 Re: Putting Motor In
    Apr 2009
    stockton ca
    Well shoot thats makes it sound so easy any ne can do it Lmao
  4. #4 Re: Putting Motor In
    PA
    2001 GSE
  5. #5 Re: Putting Motor In
    Outer Space
    Link no worky for me
    EDIT: Got it ! nevermind.
    02 GTP 13.6 @ 100mph - SOLD
  6. #6 Re: Putting Motor In
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    My writeup should work for ya, atleast for a general idea. For a novice, might take about 8+ hours.
    http://www.grandprixforums.net/f73/l...deo-23248.html
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  7. #7 Re: Putting Motor In
    Apr 2009
    stockton ca
    Damn 8 hours to install and it only took us 4 drunkin hours to pull lol
  8. #8 Re: Putting Motor In
    Ohio
    i got it down to a system lol, 37 min from start to finsih with it out and on the stand lol
  9. #9 Re: Putting Motor In
    Apr 2009
    stockton ca
    if i do another one im pretty sure i can have it out in around an hour and a half but that includes marking every thing bagging nuts and bolts and so on
  10. #10 Re: Putting Motor In
    Nov 2008
    Well i'm basing it on a novice taking his time. First time it took me 6 hours to pull the motor and put the new one back in (trans included)... Taking a break to eat dinner haha
  11. #11 Re: Putting Motor In
    Apr 2009
    stockton ca
    then thats fair i guess
    Some guys doing a 350 in my class took like 10 hours pulling the engine from a 92 chevy it was ridiculous to watch and it was the gm asep students group
  12. #12 Re: Putting Motor In
    Ohio
    wtf? that engine harness is honestly the size of my thumb...im doing a headgasket job on a 90 chevy truck in my class right now lol. now the 350's in the vandura are hard! you gotta take radiator support and grill and everything out and yank it out the front.
  13. #13 Re: Putting Motor In
    SE Level Member Boostd1's Avatar
    Thornton, Colorado
    Quote Originally Posted by kfish View Post
    Dammit! Haha
    Guess I'm not up to par with my 45 minutes
    "The only sustainable competitive advantage is the ability to learn faster than the competition."
  14. #14 Re: Putting Motor In
    Nov 2008
    I tend to take my time. An hour and a half start to finish AND running
  15. #15 Re: Putting Motor In
    Apr 2009
    stockton ca
    It was a cluster phuk They left the top trans bolts in and had it under load of the engine hoist triing to take off the engine mounts and then they couldnt figure out how to move it to the yard once it was out cause the trans was moving cause they didnt just pull them together like I told them to do It was bad I pulled one out of a 90 in my front yard in an hour with zero exp
  16. #16 Re: Putting Motor In
    Ohio
    wow
  17. #17 Re: Putting Motor In
    Quote Originally Posted by wickedintent79 View Post
    Wow... Had one outta an 85 F-body. Dropped the drive-shaft, dropped the tranny (manual so it wasn't bad and there were three of us), disconnect the few things actually hooked up to the engine, pop distributer cap, pull the engine. Done.
    I don't see how this is difficult by any means. Just need the proper tools.
    I realize keeping the tranny attached is easier, but for since it was a manual is wasn't that bad.
  18. #18 Re: Putting Motor In
    PA
    *bows to all the self-proclaimed professionals in this thread*
    2001 GSE
  19. #19 Re: Putting Motor In
    Apr 2009
    stockton ca
    It was definatly a funny thing to watch
  20. #20 Re: Putting Motor In
    Nov 2008
    Quote Originally Posted by Zef_66 View Post
    Hey, when you motor/trans swap enough times, you get the right to brag.
  1. Anyone ever try putting a 5 speed or something in a 97+ GP?
    By salannelson in forum General Tech Discussion
    Last Post: 11-15-2009, 01:11 AM
  2. Putting a supercharger in a GT/ 5speed
    By CMURDAx in forum General Tech Discussion
    Last Post: 07-27-2009, 01:04 AM
  3. putting those vinyl inlays on how do i do it
    By olds95supreme in forum Visual/Body Modifications
    Last Post: 07-15-2009, 11:26 AM
  4. engine revs when putting into gear
    By breeze12 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-07-2009, 09:28 AM
  5. Putting the car in Reverse while driving.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-05-2008, 10:22 PM
