Thread: (FWI) Fenderwell intake...how does it affect MPG?
Results 1 to 10 of 10
  1. #1 (FWI) Fenderwell intake...how does it affect MPG?
    detroit
    hey everyone, I've been planning a build for my custom FWI, and wanted to know everyone's EXPERIENCE about fenderwell intakes, please DO NOT say sht unless you know what you're talking about to avoid confusion..for me and anyone who plans on installing a FWI
    -also if you know how much horsepower gain it provides, spill it!
  2. #2 Re: (FWI) Fenderwell intake...how does it affect MPG?
    okay, here is the dirty:
    for someone to create an FWI and for it to be beneficial you need it to be 4" piping with a maximum bend of 22.5* and the biggest cone filter you can find. the problem with it actually being in the fender is that you have to put a big bend in it which i dont care for. i think so long as you get it close to the fender opening then youre golden.
    if youre looking for the most power overall you should do well with some form of a short ram like i mentioned above. once you get past a 3.4 setup (if you have a GTP) its really best to just run an open cone (right off the throttle body).
  3. #3 Re: (FWI) Fenderwell intake...how does it affect MPG?
    detroit
    hey bio, .......ok..so i don't plan on dropping in pulley size anytime soon (no plans either)...what do u recommend for maximum increase in mpg and performance with my current setup (u-bend/cat delete)/future pcm?
  4. #4 Re: (FWI) Fenderwell intake...how does it affect MPG?
    a nice 4" intake that goes near the fender would probably be the best.
  5. #5 Re: (FWI) Fenderwell intake...how does it affect MPG?
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Essentially with an intake setup (without an IC or Spray) you want the incoming air to be as close to the ambient temp as you can while STILL keeping the bends in the tubing to a minimum.
    I personally like a CAI instead of a FWI. The downfall however is price as the price for a CAI is much more then a homemade FWI. And in reality the gains aren't that significant.
    Make this.
    2006 Grand Prix GXP
  6. #6 Re: (FWI) Fenderwell intake...how does it affect MPG?
    Wausau, WI
    I have the same or better MPG's before and after the FWI, and I noticed a definite improvement over the stock intake performance wise, both sound, throttle response and maybe a little bit of power. My guess would be maybe 5 HP
  7. #7 Re: (FWI) Fenderwell intake...how does it affect MPG?
    Serena, IL
    Do the FWI's suck up any water, im just wondering about driveability, as my GTP is a Daily Driver
  8. #8 Re: (FWI) Fenderwell intake...how does it affect MPG?
    Joliet, IL
    Quote Originally Posted by xringshooter7 View Post
    no you'll be good....dont go puddle driving like a truck tho...
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  9. #9 Re: (FWI) Fenderwell intake...how does it affect MPG?
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    I got an MPG drop after my intake install. I went from an average of 19.5 MPG (mostly city driving) down to 18.0 MPG after the install. I would chalk up about .5 MPG to the fact that I drove the car a little harder after the install so that I could enjoy the whine of my supercharger, so about a 1 MPG drop overall, but a nice boost in performance, and a good hit of pure fun.
    As for the water, I have often wondered about putting some sort of "deflector" inside the fender that would prevent water from getting splashed up inside from a large puddle or something, but I haven't done it. When I do take my car to the car wash (for those times that I don't have the time to wash it by hand) I make sure that I don't get the "undercarriage wash"... No sense in having the car wash spray pressurized water in my intake area!
    Other than that, you should be fine. Small puddles are no problem since the water doesn't splash up until the tires (behind the intake area) hit it.
    Currently driving a 2006 Grand Prix GT - Stock
    2000 GTP was killed by 16 year old - Nov 20, 2010 - It only had 74,000 miles, a ZZP 3" Catted Downpipe, ZZP SS PLOG, FWI, 180* T-Stat, Flipped Dog Bones, GMPP Sway Bars, G2 painted Rotors and Calipers, HUMount, and was Dexcool free!
  10. #10 Re: (FWI) Fenderwell intake...how does it affect MPG?
    Serena, IL
    Okay, thanks
    That was a big prob on my last car, 2002 Trans am with an STS Turbo, you would drive it in just the littlest puddles, and you'd suck water into the turbo...not good
  1. Make A 4" Fenderwell Intake (FWI)[*]
    By Street Wolf in forum How To Write-Ups/Tech Tips
    Last Post: 05-17-2019, 05:23 PM
  2. Custom FenderWell Air Intake Kit, NEW
    By scottmmckinney in forum General Tech Discussion
    Last Post: 06-17-2009, 01:32 PM
  3. Winter affect on kr?
    By GTP4 in forum PCM Tuning
    Last Post: 12-21-2008, 10:35 AM
  4. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
