[Have been annoyed lately at a strange odor coming in with the fan on so I went to check under the hood after starting the motor to see if there were any signs of rodents or something getting cozy in there and maybe causing the smell.]
Didn’t find anything other than the fact that I can feel a strong air blowing upwards from the power steering pump/alternator area behind SC snout. Literally holding my hand a couple of inches above the alternator I could feel as if there were a fan turned on facing upwards. For why?
I know after getting LIM/SC and valve cover gaskets done I could hear what sounds like a vacuum leak but all lines have been checked and replaced as needed and the only explanation could be is after the intake being super cleaned I can just hear the intake more than normal because of the lack of carbon buildup.
Still not sure why there should be such a strong, cold wind back there. I figured if there’s an exhaust leak from the manifold on that side, it would be louder and affect performance and I honestly haven’t felt either symptom.
