Thread: 99 GTP, two issues at once. Are they related?
Results 1 to 20 of 28
  1. #1 99 GTP, two issues at once. Are they related?
    Jan 2014
    AR
    Alternator idiot light came on for a minute or so at a time last week. This week I swapped on a known good alternator. Seemed fixed for about 15 miles then the light came on. Within half a minute it stalled. Starts normally, consistently, but dies in a couple seconds. Seems like theres plenty of battery. Took green cap off evap port, press valve with pocket screwdriver. Nothing there. Replaced fuel pump a couple years back.
    Seperate problems? New fuel pump then diagnose charging issue or am I missing something like security or oil pressure or rollover switch? Computer fried from low voltage? Plugged fuel filter? What could cause the charging system light to be on besides the alternator? Wiring appears intact.
    I am a bodyman, no EFI mechanic and working outside in cold with very little time, funds, or tools. What is the sane course of action? Thanks.
  2. #2 Re: 99 GTP, two issues at once. Are they related?
    did you mean fuel rail port? has no gas pressure?
    id try a volt meter on the battery engine running, see what its putting out. check all the battery cables too. the thin one alt to fuse box too.
    if you see bare wire at the end good chance that cable is bad.
    also load test the battery, it could be on its last legs. parts stores cant test the voltage and load test for free.
  3. #3 Re: 99 GTP, two issues at once. Are they related?
    Jan 2014
    AR
    My mistake, I was at the wrong valve. Fuel rail schrader valve spews gas when pressed. Pump runs with normal sound.
    Engine only runs for one or two seconds and dies. Not that fast with my meter, lol. But when the light first appeared I did that and saw it ranging between 13.6 and 14.2 volts. Did not recheck with the 02 alt, got towed home. See story in prev post.
    Fuse box feed looks perfect as does alt wiring, and just now sitting still, theres same 12V everywhere as at battery terminals.
    Battery is about a year old.
    It starts right up but dies immediately.
  4. #4 Re: 99 GTP, two issues at once. Are they related?
    we working on the gtp or gt?
    gtp could be the hi speed resistor, try the relay bypass.
    edit its the gtp lol in the fukin title lol
  5. Likes Supercharged99 liked this post
  6. #5 Re: 99 GTP, two issues at once. Are they related?
    Jan 2014
    AR
    High speed resistor? Relay bypass? Are we talking heater stuff? What relay where and what to jumper? Yea, 99 gtp coupe with boobatune.
  7. #6 Re: 99 GTP, two issues at once. Are they related?
    Jan 2014
    AR
    Cruise control quit on the GT but thats another matter entirely. I need to check out brake noise on it so I can use it while the P is down.
  8. #7 Re: 99 GTP, two issues at once. Are they related?
    the gp, check that both third brake light bulbs are working, when they go out it kills the CC. you get tot them from the trunk underside of the rear deck there under the light.
  9. #8 Re: 99 GTP, two issues at once. Are they related?
    Jan 2014
    AR
    Fuel pump resistor, duh. I may have the whole relay box off the 02 here. Thanks and yeah, didn't check them bulbs yet. When it rains it pours. Me go see about GTP...
  10. #9 Re: 99 GTP, two issues at once. Are they related?
    Jan 2014
    AR
    I been out there trying to push it into the garage. That ain't happening with one IDJ but one SD could probably handle it. Regal is just about history, eh?
  11. #10 Re: 99 GTP, two issues at once. Are they related?
    Quote Originally Posted by idrivejunk View Post
    shes sold. guy dropped off a deposit today, picking it up later this week. daddy needs torque converter money for the ss camaro. its like a grand for the tc i need.
  12. #11 Re: 99 GTP, two issues at once. Are they related?
    Jan 2014
    AR
    Hope its a good home for it. Go fast part, must.
    OK it runs with tab 85 bent out, now whut?
  13. #12 Re: 99 GTP, two issues at once. Are they related?
    Jan 2014
    AR
    The battery teminals were funky as a corpse. And the A/C diode was just found to be a crispy critter which I yanked. Its been sans A/C for months now, I run a pulley.
  14. #13 Re: 99 GTP, two issues at once. Are they related?
    well you fixed it, and just leave it that way if you like. or you can buy a new resistor and replace the old one. some cars its on the fire wall by the heater hoses, or in most its inside the fender near the battery. theres a push tree clip holding it in place. looks like a long horse shoe.
  15. #14 Re: 99 GTP, two issues at once. Are they related?
    and this is the new toy that replaced the regal. just got a dod delete, cam headers dyno tuned. 443 whp its getting a blower next winter.
  16. #15 Re: 99 GTP, two issues at once. Are they related?
    warm start outside. thats the stock cat back too.
  17. #16 Re: 99 GTP, two issues at once. Are they related?
    Jan 2014
    AR
    Wicked. Yeah you need more stalls fer dat raspy sucka.
    Alright then, thanks man. I just read old threads and now know the Bill-isms on the subject. I am going to have a look into fiding the resistor and seeing if I have the 02 one. Live (and read and ask, but not always in that order), and learn.
  18. #17 Re: 99 GTP, two issues at once. Are they related?
    Jan 2014
    AR
    Don't make me counter with 455 exhaust vids. You'd hate to get out cooled by some raggedy carbed heap.
  19. Likes Scottydoggs liked this post
  20. #18 Re: 99 GTP, two issues at once. Are they related?
    as the pic posted states on the bypass, 97-00 cars only have this resistor.
    and thanks. 3k stall is hi on the list. in all i have 3 cars now. one to many. so figured id ditch the poor old regal. and it frees up some cash for that TC and trans cooler and install costs.
  21. #19 Re: 99 GTP, two issues at once. Are they related?
    Jan 2014
    AR
    Three rides is a parking stretch, I gotta agree to that. Somebody backed into the GT in the street dammit.
    But boy you just made my day, pointing me in the right direction. Again. Many thanks. Off I go, to prime the carb.
  22. #20 Re: 99 GTP, two issues at once. Are they related?
    three pumps and crank it lol
  1. Few (possibly related?) issues with my GTP
    By Brammer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2017, 10:56 AM
  2. Headlight switch issues related to melted HDM relay?
    By wytnoyz in forum 04+ Specifics
    Last Post: 01-03-2015, 08:14 PM
  3. Two problems. Are they related?
    By jman44 in forum Introductions/Noob Questions
    Last Post: 07-19-2013, 02:08 PM
  4. non gp related question
    Last Post: 05-20-2009, 07:15 PM
  5. PCV problems-Related to I/C
    By TDCRacing in forum General Tech Discussion
    Last Post: 08-31-2008, 06:43 AM
