Thread: Short Stack Intercooler with Dual Pass Front Mount?
Results 1 to 9 of 9
  1. #1 Short Stack Intercooler with Dual Pass Front Mount?
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    Has anyone tried running the short stack intercooler core with the dual pass heat exchanger and maybe a higher flow rated pump? Just curious if all the claims of heat soaking is just from the front mount.
  2. #2 Re: Short Stack Intercooler with Dual Pass Front Mount?
    May 2008
    Schuyler, NE
    It's mostly due to the volume of the system. You can add a lot of heat absorbing capacity to it by installing a good sized reservoir. A higher flowing pump never hurts, along with a bigger fmhe.
  3. #3 Re: Short Stack Intercooler with Dual Pass Front Mount?
    Sep 2018
    NC
    Thats what i was thinking and yes i would love to do the full sized but the cost for the fuel rail solution and then making the intake not hit the hood is too much for a college student right now. I was thinking if i relocated the battery thats a large space for a nice sized reservoir.
  4. #4 Re: Short Stack Intercooler with Dual Pass Front Mount?
    short stacks kinda suck. no idea why they make the in and outlet tubes so damn small either.
    i got a fsic, and cut up a stock rail and made my own modded rails. cost me 20 bucks.
    Short Stack Intercooler with Dual Pass Front Mount? Attached Images
  5. #5 Re: Short Stack Intercooler with Dual Pass Front Mount?
    Sep 2018
    NC
    I was thinking about doing that with my rails but I havnt heard of anyone modifying the returnless rails before
  6. #6 Re: Short Stack Intercooler with Dual Pass Front Mount?
    you could use a l67 rail, remove the fpr and just use the inlet tube to the rail.
  7. #7 Re: Short Stack Intercooler with Dual Pass Front Mount?
    Sep 2018
    NC
    And just cap off where the FPR was?
  8. #8 Re: Short Stack Intercooler with Dual Pass Front Mount?
    the small line would be removed with the fpr. it comes off the fpr.
  9. #9 Re: Short Stack Intercooler with Dual Pass Front Mount?
    Jul 2017
    macomb mi
    maybe dual pumps may help as well im doing a dual ss build and I basically have 2 of everything except 1 reservoir both systems take from and feed into the same reservoir that way if one is way cooler than the other they will balance out I got my second (weaker) pump out of an Mercedes m class I believe took only 5 min to remove and cost $15 I believe. maybe you could do one for each front mount
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  1. Short stack intercooler
    By Garandpa in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2016, 10:17 AM
  2. 07 GP ZZP Short Stack intercooler question
    By Woosterdelt in forum General Tech Discussion
    Last Post: 08-31-2014, 03:01 PM
  3. XPZ cam and SHORT STACK intercooler
    By Dcards in forum For Sale - Parts
    Last Post: 06-25-2014, 02:17 PM
  4. Short Stack Intercooler [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-30-2012, 04:20 PM
  5. Short Stack Intercooler ????
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-22-2010, 12:24 PM
