Thread: 2004 GTP Comp G .... Need new vacuum tee that attaches to LIM under SC Snoot
Results 1 to 10 of 10
  1. #1 2004 GTP Comp G .... Need new vacuum tee that attaches to LIM under SC Snoot
    Nov 2012
    Tracy, CA
    Anyone know where I can get one of these ? Mine is cracked and seems to be causing a vacuum leak.
    I believe it is the root cause of a P0068 / P0101 code condition I had recently.
    Seems that the MAP sensor was not getting the vacuum level it expected.
    Thanks....
  2. #2 Re: 2004 GTP Comp G .... Need new vacuum tee that attaches to LIM under SC Snoot
    go to advanced auto, they got small white T's, 2 in a pack for 2 bucks. then buy 6 inches of vac line, cut it into 2 inch parts, then push one on the nipple on the lim, then push the two hard lines into the other two vac line parts, then put that t in place. all fixed up for under 5 bucks.
  3. #3 Re: 2004 GTP Comp G .... Need new vacuum tee that attaches to LIM under SC Snoot
    or just replace all the hard line. then just buy about 3 foot of vac line.
    https://oi1097.photobucket.com/album...1.jpg~original
  4. #4 Re: 2004 GTP Comp G .... Need new vacuum tee that attaches to LIM under SC Snoot
    https://i1097.photobucket.com/albums...b/limjob11.jpg try that link. if it dont open hit the magnifying glass icon in the top right corner of the pic.
  5. #5 Re: 2004 GTP Comp G .... Need new vacuum tee that attaches to LIM under SC Snoot
    May 2008
    Schuyler, NE
    I'm not a big fan of those white plastic tee's. Personally, I would just buy this and replace it all.
    Supercharger GM Vacuum Harness Pontiac Eaton M90 Grand Prix GTP GT 3800 L32 | eBay
    Or zzp sells a kit that uses brass tee's.
  6. #6 Re: 2004 GTP Comp G .... Need new vacuum tee that attaches to LIM under SC Snoot
    those t's have been in use for like 8 years now easy. working just fine.
  7. #7 Re: 2004 GTP Comp G .... Need new vacuum tee that attaches to LIM under SC Snoot
    Jul 2017
    macomb mi
    yea id replace it all just dealt with replacing all my windshield washer hose while i was just trying to pacth it up i would patch it up and it would break somewhere else a week later happened a third time and drove angrily to home depot to get some tubing after i found what they needed i drove calmly home haha
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  8. #8 Re: 2004 GTP Comp G .... Need new vacuum tee that attaches to LIM under SC Snoot
    May 2008
    Schuyler, NE
    I've had those tee's break after a year of heat cycles. They are cheap plastic.
  9. #9 Re: 2004 GTP Comp G .... Need new vacuum tee that attaches to LIM under SC Snoot
    Nov 2012
    Tracy, CA
    Thanks to all.
    I see that new hardline assembly is about $30 with shipping and it will take a week to get to me here on the West Coast....
    I will try ScottyDoggs lower cost solution.... I can do that tomorrow ....
    ScottyDoggs.... do you remember what diameter vacuum hose that is ?
    And again, great joda avatar !
  10. #10 Re: 2004 GTP Comp G .... Need new vacuum tee that attaches to LIM under SC Snoot
    Jul 2017
    macomb mi
    zzp sells a better assembly for $20 or you can even make your own out of the stuff they use if you have the time and save 5 to 10 bucks
  1. 2004 Gran Prix pulling a vacuum in fuel tank
    By sloppijoes in forum General Grand Prix Discussion
    Last Post: 09-18-2014, 10:05 PM
  2. 2004 Comp G
    By 04noobprix in forum Introductions/Noob Questions
    Last Post: 04-08-2014, 11:07 PM
  3. Replies: 10
    Last Post: 11-15-2013, 10:55 AM
  4. Replies: 15
    Last Post: 03-28-2012, 10:46 AM
  5. my new 2004 Comp G!
    By colindunn in forum Off Topic Discussion
    Last Post: 10-31-2010, 08:57 PM
