Thread: felpro plastic LIM quality
Results 1 to 3 of 3
  1. #1 felpro plastic LIM quality
    Jul 2017
    macomb mi
    just relized the LIM gasket I ordered are the felpro plastic ones not the metal they are not even worth it to take back do I just cut my losses with these and get the metal ones I believe the current ones are metal on my car as I have a 2004. or are these felpro plastic gaskets not so bad let me know
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  2. #2 Re: felpro plastic LIM quality
    HUDSON
    I installed the Fel PRo plastic LIM gaskets on my car in 2009, and converted to conventional green coolant, not knowing about the metal ones. However I changed them again to the metal ones in 2018 just as a maintenance precaution, as I was noticing small amounts of coolant (non dexcol, converted to conventional green) on the intake manifold. Upon removal of the plastic Fel Pro gaskets, they had cracked just as the factory ones showed in 2009.
    Pictures are below:
    Browser no longer supported
    The decision is up to you, but I would only use the metal gaskets (if available). The plastic ones work, but fail eventually over time.
  3. #3 Re: felpro plastic LIM quality
    Jul 2017
    macomb mi
    that's all I need to hear lol oh well I did only pay $11 for them and they came with a tube of rtv so its not all bad if I bought the same tube it would probably be $5 at oriellys haha but yea for some odd reason they looked metal in the pic but after receiving them and taking a closer look at the pic and part # I realized ive been dooped lol kinda mad too because rockauto says 2nd design which just makes me assume metal design haha
  1. Various gaskets in felpro lim kit
    By FriboRage in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2018, 09:22 PM
  2. felpro or mls gaskets?
    By DaytonaGTP500 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2013, 12:04 AM
  3. Felpro vs Thermoseal
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2012, 06:17 PM
  4. Loud clunking sounds like plastic hitting plastic
    By ADrugDealer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-12-2012, 07:50 AM
  5. LIM gasket - felpro or GM
    By cavGTP in forum 04+ Specifics
    Last Post: 12-03-2010, 12:30 PM
