Thread: Planning my mods, need advice
Page 10 of 14 FirstFirst ... 89101112 ... LastLast
Results 181 to 200 of 272
  1. #181 Re: Planning my mods, need advice
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Hi Folks its been a while, ive been consumed with other projects. Ive taken the regal to a few car shows and she is an absolute hit. Most people my age have no idea what it is other than an old guys car. (im 25) I pop the hood and with the IC belt wrap and SC people flock to it and gawk.
    WIth the zzp BF sale coming up i want to get some more stuff for the car. I know i need one of their modified fuel rails. the one i made has a vacuum leak and i cant tune it because the fuel trims are all over the place. I have a few other items im thinking about picking up if there is a good deal.
    1. N* TB and adapter (with the mods i have will this help? I never ported the SC inlet and dont plan to any time soon)
    2. More pulleys. (i think with the stuff i have on hand i can run smaller than a 2.9 once its tuned)
    3. F body brakes.
    I have a powerlog for the front bank i just need to install. Is there anything else you guys think i should watch for? I want to do meth, but thats probably out of budget.
    RIght now i have:
    2.9 pulley
    ported SC outlet
    Ported LIM
    ZZP FSIC
    e85
    80#
    1.9 rockers
    DP
    Powerlog
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #182 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Chats
    265
    The n* will help, but you are leaving most of the power on the table without porting the inlet to match.
  3. #183 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Just how much of a difference does porting the inlet make? Are we talking measurable difference on the dyno?
    I have a dyno pull scheduled for the 13th. I hoping to put down at least 280. My goal with the build has been to put down more power on the dyno than my Volvo made at 280 AWHP and 360 tq. Dont know if im there yet. By the time i dyno, ill have the power log and a 2.8 on it.
  4. #184 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    Chats
    60223
    this is why people do a gen 5 swap. because the inlet is already 75mm, which is also the diameter of the northstar. a bigger inlet makes maybe 10 more horsepower, I don't really know for sure, but the butt dyno really likes it.
  5. #185 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Chats
    265
    Yeah that's a huge advantage to the Gen 5.
    I would estimate 10-20 up by opening it up.
  6. #186 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Chats
    265
    Hp not "up". Can't edit the post for some reason.
  7. #187 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Quote Originally Posted by SgtMarshal View Post
    When i ordered my IC i ordered it for a gen 3, will a Gen 5 work with the Gen 3 IC core? If so i may begin looking for one. If not, My next big step will be a proper cam or a turbo.
  8. #188 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Chats
    265
    Yes, the outlet is a bit different, but it works.
  9. #189 Re: Planning my mods, need advice
    Chats
    243824
    i got a gen 5 on a gen 3 fsic. it works just fine.
  10. Likes Gingershrek liked this post
  11. #190 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Would i have to port the gen5 outlet like i did with the Gen 3? I can use the same lower intake since the FSIC is in between right?
    If zzp drops their price on their used gen5 I might just pick it up. I really want to put down some impressive power numbers on the dyno.
  12. #191 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Chats
    265
    There's no reason to touch the outlet on a gen 5. It doesn't have those bolt bosses like the 3 does. It's already about as good as it's going to get.
  13. #192 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Hey folks,
    Back again on another modding Binge.
    I have:
    Meth
    wideband o2
    North star adapter kit
    All coming in the mail.
    I have a few quesitons.
    1. Will any of the North star kits work or is there anything specific i need to buy
    2. Is my stock trans going to detonate the first time i hit power? (I never launch it, i roll into power)
    3. will porting the inlet on the SC give me more SC whine?
    4. Should i start working on a 3" cat back? I have the power log and the DP, but the rest is the nasty 2.5" factory single exhaust. Ive watched a few episodes of engine masters where they showed that 2.5 can definitely kill power on a higher output engine.
  14. #193 Re: Planning my mods, need advice
    Apr 2015
    Columbus, OH
    Chats
    246
    Just get the adapter you need, either gen 3 or 5. Your trans will probably be fine if you don't beat on it. But it also could break. Mine has been good for 5 years with a fair amount of thrashing. But I anticipate issues eventually. No, porting will not make it whine. And if you like the whine, meth will make it even quieter. Exhaust I'm not positive, but I think you need to be making some decent power before it's an issue. Maybe 350-400 wheel? Not sure but I wouldn't worry with what mods u have.
    Top Swapped 01 Imp
  15. #194 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Quote Originally Posted by bandook View Post
    I have the Gen 3 SC, just want to make sure that any N* will work.
    I guess that means i will need to go to a 2.6 inch pulley or something at some point.
    Mods as a refresher:
    e85
    80# injectors
    AEM 340lph e85 pump
    1.9 rockers
    ZZP FS IC
    Power log
    ZZP DP
    zzp Fuel rails
    zzp Belt Wrap
    2.9 (for now) pulley .
  16. #195 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    Chats
    60223
    I didn't notice any gains when I went from a 2.8 to a 2.6 with the gen 3. with your mods, you should really consider upgrading to a gen 5. one benefit from upgrading to the gen 5 is that the inlet is already at 75mm's so you don't need to port it, unless you really want some blower noises, in which case, i've heard of people porting the inlet to 90mm's and installing an LS1 throttle body with the corresponding diameter. they really sound wicked. there is one guy I would trust to do the port work, and it's not cheap. look up Steigemeier on the web. he's ported gen 5's before, and it helps, I don't know how much because it hasn't been done very often. when I was building my 2001 GTP, I went with ebay headers with an ebay downpipe that was catless. if I was going to do it again, I would have gotten a custom 3" downpipe made from a local exhaust shop or something like that. I never bothered to change the stock catback, i'm not aware of any gains to going with a 3" exhaust setup.
    on a different topic, I'm glad to see you are back, i've been curious about your builds for a while.
  17. #196 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    on the grand prix i would totally agree about the catback, but the regal has a single exhaust.
    As for the Gen 5, what all is involved in slapping it on my gen 3 FSIC?
    If i have to spend the money to get a new IC core, i might as well s tart buying turbo/cam parts.
    For the moment the plan is to let my dad attack the inlet on my stage 3 with a die grinder. until it matches the adapter plate . Is there any reason i should do this? Its basically free except for labor and an SC gasket.
  18. #197 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    As for being back, my interests tend to roam, i have 4 cars and each one of them is a project.
    99 tahoe (1200 bucks)
    2019 Mustang GT (Steeda coilovers, subframe brace, camber kit, bushing inserts, front/rear sways, lund e85, 472 rwhp)
    2017 GTI (golf R turbo, Coilovers, rear sway , upgraded intercooler 350ish whp and 420_tq)
  19. #198 Re: Planning my mods, need advice
    Apr 2015
    Columbus, OH
    Chats
    246
    I was considering doing a 2.6 on my Gen 3 but said heck with it and got a Gen 5. Gives me a little more room to mod. Like Marshal said, going lower than a 2.8 is really only making more hot air. But maybe in your case there is a gain to be had since you are cooling that hot air. I didn't know that porting it would make more noise. But when u spray it with water, it does quiet it a good bit. I turned the meth off to get a good non meth tune and realized this. It's noticably louder.
    Top Swapped 01 Imp
  20. #199 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Alright fellas ,
    What is involved in swapping to a gen 5 on a gen 3 FSIC?
    Also i just ordered the Gen 3 north star adapter plate, can i make that work or does it have to go back?
  21. #200 Re: Planning my mods, need advice
    Apr 2015
    Columbus, OH
    Chats
    246
    Gen III Gen V Intercooler differences
    I think you can do it. I'm still researching intercoolers myself. Almost pulled the trigger on the new zzp intercooler, then talked myself out of it. Now I'm talking myself back into it.
    Pretty sure the TB adapter won't work. Gen V is 4 bolt, 3 is 3 bolt. Besides, gen V is 75mm. 3 is 70?
    Top Swapped 01 Imp
  1. New guy advice for mods
    By Cory2236 in forum Introductions/Noob Questions
    Last Post: 04-02-2017, 02:16 PM
  2. Planning next MODS.
    By rickisrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2017, 07:29 AM
  3. what do you think? need some advice on mods.
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 06-10-2012, 12:07 PM
  4. some advice on my mods?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 02:16 PM
  5. Mod advice from those w/o mods
    By IndeedSS in forum The Rant Forum
    Last Post: 03-09-2008, 08:26 PM
