Thread: Planning my mods, need advice
Page 9 of 14 FirstFirst ... 7891011 ... LastLast
Results 161 to 180 of 272
  1. #161 Re: Planning my mods, need advice
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Yeah I saw that. I'm not sure why though. Now you have a rail that can leak.
    because after a week of trying to get answers out of ZZP about how they installed, and even getting an answer from the guy who supposedly designed it, i was nowhere near closer to figuring it out. There wasnt a way to install them that i could find that didnt crimp the fuel lines, and ZZP couldnt help.
    Only reason i have the fire extinguisher is that these are unproven. So far not a drop has come out.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #162 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    So two questions now:
    I have an exhaust leak from my rear manifold to the DP. One of the nuts is starting to round. I want to replace it, any idea which one i should get without removing it?
    2. the 90* elbows were mentioned for the IC hoses. Where/what should i get.
  3. #163 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Chats
    265
    Those nuts are m10-1.5.
  4. #164 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    Chats
    60223
    you can get dayco curved radiator hose part number b71469
    here is a link where I read about someone using it
    Hybrid Phenolic Intercooler Aluminum/Phenolic w/ VW radiator install
  5. #165 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Thanks for the info guys. After some data logging yesterday i realized the car was running lean at idle, but more or less right at cruise. I used some brake clean, and found that once the engine heats up a little, the Pulley side rear injector is sucking in air. I tried reseating it quickly with no luck. I suppose im going to have to lift the rail up and replace the O ring.
  6. #166 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    I also did some full power pulls yesterday, and found that there is some KR on shift. Isnt there a way to richen up the fuel when shifting? Once i get the Plog and the tune dialed in, im going to kick the WOT timing to 20 and see if she complains. If not, then im getting me a new pulley.
  7. #167 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    Chats
    60223
    are you running E85 now?
  8. #168 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Quote Originally Posted by SgtMarshal View Post
    Ive been on e85 for a while.
  9. #169 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    So something strange. I replaced the O rings on the rear injectors and im still getting vacuum leaks. The fronts are fine. Im going to try adjusting there the clip sits on the injector. There are 3 areas. The fronts are fine, but im guessing there is some minor difference with the brackets on the rear rail keeping the injectors from droping into the holes.
  10. #170 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    Chats
    60223
    did you lube up the o rings before you put them in?
  11. #171 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Yep,
    I removed the rail again, (partially) and found put i cant use the clips any other way. What i also found out is that the alignment of the rail seems to be off. Im not sure what its supposed to be, but i think the angle isnt right and the injectors arent sealing properly against the head. I think part of this is that one of the brackets is contacting with the IC. I cut it back, but probably not enough for the rail to properly align.
    My 1st thought is to take the injectors out of the rail and stick them in the head. See what the natural alignment is. If the rail doesnt match, then adjust till it does.
    other than that im out of guesses.
  12. #172 Re: Planning my mods, need advice
    Apr 2015
    Columbus, OH
    Chats
    246
    Maybe double check the vacuum line that runs back side of injectors to the map. I had a vacuum leak that I thought was injector but the vac hose had a hole in it. Just a thought. Hard to be 100% when spraying brake cleaner.
    Top Swapped 01 Imp
  13. #173 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Chats
    265
    You should be able to seat the injectors all the way before tightening the nuts on the hold-down stands. Can you do this, or is the alignment off?
  14. #174 Re: Planning my mods, need advice
    Chats
    243824
    its the bracket that you bolt down. if you dont trim it up it hangs up on the corner of the ic core. hes using a modded stock rail like i did.
  15. #175 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    So i thought id throw an update out. I havent been on much because ive just been waiting for the new fuel pump. The old one siezed up (new from AEM) I sent it back and 2 weeks later they sent me a new one. I got it installed last week, and the car runs fine. I honestly havent done much more than that since I also bought a 2019 mustang GT last tuesday. (its a hoot) last night i took her for a drive to fill up on ethanol since it was showing just below a quarter of a tank. 3 miles later it ran out of gas on the side of i95 . I managed to pull over far enough that i wasnt in the travel lane (barely).
    I will say the pull from the new setup is nice. The next step after fuel, is to re design the fuel rail solution using AN fittings and steel braded line. It should remove the tension that is causing it to not fully seal in the rear.
  16. #176 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    Chats
    60223
    did you ever get that vacuum leak figured out?
    that sucks about running out of fuel
  17. #177 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    The car has been stuck at my apt immobile while i waited for the fuel pump unfortunately. There was no way to test it out. Next weekend I am going to my dads house to rebuild the fuel rail. I know the leak from the rear injectors not seating properly. the fronts seat just fine, so im confident its not the injectors.
  18. #178 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    I was able to get the fuel pump connections fixed and i have been driving it for the last 3 weeks. It has been purring like a kitten .. on e85.
    been a busy few weeks my mustang got rear ended and i picked up a $1200 tahoe so the regal is on hold for a bit since she is running and driving.
    I seem to recall that there is a way to tune the car for cold starts but not using HPT. Is that correct?
  19. #179 Re: Planning my mods, need advice
    Kemmerer, Wyoming
    Chats
    60223
    that is correct. you need to use tiny tuner and a dhp tuner to tune for cold starts. is the mustang totalled?
  20. #180 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Chats
    7334
    Mustang had minor damage thankfully, its almost as good as new now!
  1. New guy advice for mods
    By Cory2236 in forum Introductions/Noob Questions
    Last Post: 04-02-2017, 02:16 PM
  2. Planning next MODS.
    By rickisrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2017, 07:29 AM
  3. what do you think? need some advice on mods.
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 06-10-2012, 12:07 PM
  4. some advice on my mods?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 02:16 PM
  5. Mod advice from those w/o mods
    By IndeedSS in forum The Rant Forum
    Last Post: 03-09-2008, 08:26 PM
