Thread: Planning my mods, need advice
Page 6 of 14 FirstFirst ... 45678 ... LastLast
Results 101 to 120 of 272
  1. #101 Re: Planning my mods, need advice
    Antioch, IL
    lol those 56k days, what fun times they were.
    2009 Challenger SRT8
    Expert at being gay.
  2. #102 Re: Planning my mods, need advice
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    One last question for folks before i make my final decision:
    With an IC, e85, 80lb injectors, ported heads LIM and SC, and 1.9 rockers and meth, what should I expect to run and trap in the quarter (ball park) This is generally what i personally consider a maxed m90 build. I dont plan to run a cam, or do anything extreme with intercooling.
    What about a precision 6262 with Intercooling e85 and rockers?
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  3. #103 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Upper 13's with bad traction. Upper 12's with good traction.
    Turbo, it's going to depend a lot on how aggressive you get. Low boost and street tires will be in the 13's. High boost and slicks will get you 10's.
  4. #104 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    That's also assuming your track isnt on top of a mountain.
  5. #105 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Im about sea level,
    and lets say 400whp on the turbo, with slicks, what kind of traps am i getting?
  6. #106 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Should be right around 115mph, running low 12's. Maybe upper 11's.
  7. #107 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    What do people do with their ECU when they remove the stock intake?
  8. #108 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Just found out the ship time on a z3 kit is like 2 months. That definitely pushes me back towards the IC (pending shipping time)
    Final questions before i order stuff ( i promise)
    1. What size pulley would you folk run with: rockers, intercooler, e85
    2. What would you run just with full e85
    3. what would you run with Just the IC on pump gas and rockers?
  9. #109 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Most people zip tie the computer to the frame that's right under the air box. The blazer pcm tray also works great for holding it.
    1. 2.7 or 2.8. You could probably go smaller if you want.
    2. 3.0-3.2.
    3. 3.0-3.2.
  10. #110 Re: Planning my mods, need advice
    my pcm sits where the box used to be, nothing holds it down. it dont move.
  11. #111 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Well i just dropped a Bunch of money.
    FS IC
    2.9 Pulley
    AEM e85 pump (from Summit)
    Billet fuel logs
    80# injectors
    Valve cover breather
    Belt wrap
    1.9 rockers
    I haven't decided yet, but i might pull the LIM off and port it and the supercharger. Seriously considering getting some heads from the JY and building those in my spare time.
  12. #112 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Nice. But doesnt zzp's intercooler retain Pcv function?
  13. #113 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    It does if you drill your intake... havent decided if im going to do that yet. Is there a reason to drill over using the breather?
  14. #114 Re: Planning my mods, need advice
    drill the hole. its nothing. you can do it on the engine still
  15. #115 Re: Planning my mods, need advice
    Jul 2017
    macomb mi
    where do you drill this hole? this is the first time ive heard of it and I believe I have a zzp short stack
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  16. #116 Re: Planning my mods, need advice
    Jul 2017
    macomb mi
    im in the process of modding an LIM right now
  17. #117 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Quote Originally Posted by 04lss View Post
    If you can retain pcv, it will help your engine bay stay cleaner.
    Power produced will be better with a breather.
  18. #118 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by tzerilli View Post
    Check out the how to thread on how to install a wbs intercooler there are some photos iirc
  19. #119 Re: Planning my mods, need advice
    Jul 2017
    macomb mi
    i took a look good writeup but didnt see anything about drilling a hole for PCV he is running a breather so maybe he didnt do it?
  20. #120 Re: Planning my mods, need advice
    ed had posted pics on p 2 or 3 of different lims and shows the right way to rtv it on there.
  1. New guy advice for mods
    By Cory2236 in forum Introductions/Noob Questions
    Last Post: 04-02-2017, 02:16 PM
  2. Planning next MODS.
    By rickisrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2017, 07:29 AM
  3. what do you think? need some advice on mods.
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 06-10-2012, 12:07 PM
  4. some advice on my mods?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 02:16 PM
  5. Mod advice from those w/o mods
    By IndeedSS in forum The Rant Forum
    Last Post: 03-09-2008, 08:26 PM
