Thread: Radiator Fans not working
Results 1 to 5 of 5
  1. #1 Radiator Fans not working
    Feb 2020
    UT
    I have a 2000 Grand Prix GTP. The radiator fans won’t turn on unless I unplug the coolant temp sensor. I’ve checked the relays and fuses and wiring and it’s all good. The coolant temp sensor works, the dash will show the temp, does that mean the sensor is working or could changing the sensor still fix the fans? At this point it’s gotta be either the sensor or the PCM. What is the most likely scenario?
  2. #2 Re: Radiator Fans not working
    change the temp sensor. its a two part deal, one reading goes to the dash, the other to the pcm. if the pcm see's no signal it wont turn the fans on.
  3. #3 Re: Radiator Fans not working
    Feb 2020
    UT
    I will give that a try and let you know if it works. Thanks!
  4. #4 Re: Radiator Fans not working
    theres also a short harness temp sensor to main harness, it fails too. so if you see cracked insulation or bare wire, change that as well.
  5. #5 Re: Radiator Fans not working
    Feb 2020
    UT
    Yeah I thought about that but I couldn’t find the harness at the junk yard anywhere. Changing the sensor fixed the problem though. Thanks!
  6. Likes Scottydoggs liked this post
  1. Radiator Coolin Fans not working
    By jayroca in forum General Tech Discussion
    Last Post: 07-30-2014, 07:02 AM
  2. Radiator fans not working
    By Paul Hagensick in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-18-2012, 08:25 PM
  3. Radiator Fans
    By Garry in forum General Grand Prix Discussion
    Last Post: 05-18-2012, 09:08 AM
  4. radiator fans not working
    By Wisconsingrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 07:59 PM
