Thread: Planning my mods, need advice
Page 7 of 14 FirstFirst ... 56789 ... LastLast
Results 121 to 140 of 272
  1. #121 Re: Planning my mods, need advice
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    ed had posted pics on p 2 or 3 of different lims and shows the right way to rtv it on there.
    Yeah this, ive been digging through threads.
    my stuff all arrives wednesday I am consdering taking my car to my dads house on friday and starting to work on it, that way I can friday saturday and sunday to get everything done (doubt ill need it all)
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #122 Re: Planning my mods, need advice
    i did mine in steps. mounted the pump and fmhe one morning, takes a bit longer then you like to think, front bumper has to come off, in some cases the hood latch needs to be cut, then ran my hoses up to the engine bay and res tank. ramps are your friend.
    the next week i installed the ic. had to trim the alt plastic cover. make sure the batterys un hooked too, you could hit the power cable on the alt.
    i also ran a relay to power the pump. i run it full time, when ever the key is to run, its a pumping.
  3. #123 Re: Planning my mods, need advice
    Jul 2017
    macomb mi
    alright cool found the spot and i will definitly be doing the build in multiple steps over a few weekends ill have to use a relay too can i just use one in the fuse box that isnt being used or do i need to buy a special type of relay and i seen that h-bar needs to be cut on the supercharger how neccassary is this?
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  4. #124 Re: Planning my mods, need advice
    i got a 30 amp relay, you just run key on power to the relay and wire it up like fog lights. diagrams all over the web for that crap.
    H bad you can remove, i took it out on my gen 3, left it there on the 5.
  5. #125 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Why the need for the relay? why cant it just be connected to a switched output?
  6. #126 Re: Planning my mods, need advice
    i look at it as a large power drain, relay helps. i also run my pump full time. none of that wired to the hi speed fuel fuse or what ever some do.
  7. #127 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Alright fellas, i have some questions
    1. The fuel pump doesnt seem to match up with the canister, the current idea is to hog out the bottom of it and let the pump hang there.
    is there a specific way to do it?
    2. I got zzps billet fuel logs, their website says to re use the stock pressure regulator, we cant figure out how to remove it and insert it into the regulator housing i got with the fuel logs.
    3. How the heck are you supposed to mount the belt wrap? if anyone has pictures of how its installed i would really appreciate it.
  8. #128 Re: Planning my mods, need advice
    what belt wrap you have? i got pics of a wbs and a straight bar one from a guy on fb. fpr has a snap ring holding it in. fuel pump need to sit flat at the bottom, theres a few threads with pics of how to mod the canister for the pump.
  9. #129 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    I got this bad boy, pretty sure its the WBS design, because a few weeks ago the pics on zzps website had the WBS logo on it (LMAO) Belt Wrap Kit – ZZPerformance
  10. #130 Re: Planning my mods, need advice
    it bolts to the snout, remove the stock bolts, use the longer bolts with the wrap.
    Planning my mods, need advice-006-jpg
    Planning my mods, need advice-005-jpg
    Planning my mods, need advice Attached Images
  11. #131 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Thanks for the pics scotty
    I dug through the forum trying to find the threads on how to install the pump. I only found 2 threads, one had no photos, and the other one seemed like a different canister design.
    The issue i have, is that the stock pump used plastic tube through the bottom of the canister to connect to the sock/fuel pickup The AEM pump sock is way to close to get through the hole.
    The thought is to hog out the hole a little, and wedge the pump in it. any ideas?
  12. #132 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Can you reuse the stock sock? Will that help any?
  13. #133 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    the diameter of the fitting is bigger than the new pump.
  14. #134 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    So the new pump has a smaller inlet?
  15. #135 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    Thats what it looks like, Certified to flow 340lph though.
  16. #136 Re: Planning my mods, need advice
    May 2008
    Schuyler, NE
    Hmmmm, interesting. I've never installed an aem pump, so I'm not going to be much help.
  17. #137 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    I will take plenty of pic of the housing and how the pump fits.
  18. #138 Re: Planning my mods, need advice
    Sep 2014
    Richmond Virginia
    I broke one of the rubber vacuum Ts specifically the one that connects to the front of the LIM. How do you guys replace those? Some vacuum line and a T fitting?
  19. #139 Re: Planning my mods, need advice
    Antioch, IL
    yup thats all it is
    2009 Challenger SRT8
    Expert at being gay.
  20. #140 Re: Planning my mods, need advice
    Jul 2017
    macomb mi
    I just installed an aem pump after my venturi walbro left me stranded multiple times and install was a piece of cake used just about everything in the kit zzp gave except the hose because mine was new and the pigtail connector since its the same as walbro im a 2004 but I did use the bottom of a venturi for the install but the sock fit perfectly imo I did have to zip tie the sock to the hole as it was a loose fit and any time I would try to put it in the sock would fall off I did notice right when the low gas gauge comes on you have only about half a mile till your stranded so be warned
  1. New guy advice for mods
    By Cory2236 in forum Introductions/Noob Questions
    Last Post: 04-02-2017, 02:16 PM
  2. Planning next MODS.
    By rickisrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2017, 07:29 AM
  3. what do you think? need some advice on mods.
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 06-10-2012, 12:07 PM
  4. some advice on my mods?
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 02:16 PM
  5. Mod advice from those w/o mods
    By IndeedSS in forum The Rant Forum
    Last Post: 03-09-2008, 08:26 PM
