Thread: AC condenser
Results 1 to 11 of 11
  1. #1 AC condenser
    Oct 2014
    portland oregon
    Chats
    507
    I filled my ac system with compressed air to try and locate the leak.
    with some silence I heard the hiss. It's comming from the condenser. Im afraid im the one who damaged it when I pushed the mounts for the trans cooler through it.
    My questions are
    1. Do I replace the condenser? looks kinda like a pita. however they don't cost a lot
    2. Do I buy a few cans of r-134a with stop leak and give that a shot to see if it works?
    The system lost full pressure in about 40 mins
    Sent from my SM-N920V using Tapatalk
  2. #2 Re: AC condenser
    Chats
    83662
    Replace the unit, stop leak won't fix it.
    Remove the radiator and it's pretty simple to get it out.
  3. #3 Re: AC condenser
    Oct 2014
    portland oregon
    Chats
    507
    Pita.. thanks ffdp
  4. #4 Re: AC condenser
    GT Level Member mguzzo's Avatar
    Buffalo NY
    Chats
    25
    You can replace the condenser without removing the radiator. It's a tight fit, but it can be done by removing the fans, unseating the radiator and pushing it forward, then pulling the condenser out. more conservative way is taking out the radiator though.
    and be careful putting the fans back in, be sure you seat them properly on the bottom tabs, I didn't do that and one fan wore thru my radiator and sprung a leak on the highway 3 hours from home.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. #5 Re: AC condenser
    Oct 2014
    portland oregon
    Chats
    507
    Quote Originally Posted by mguzzo View Post
    Noted thanks for the tip. My car is hardly ever 3 mins from my house lol
  6. #6 Re: AC condenser
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Chats
    3223
    Check out some youtube vids, they helped me out [being an ac noob], replace accumulator/drier & add refrigerant oil.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  7. #7 Re: AC condenser
    Oct 2014
    portland oregon
    Chats
    507
    Whats the risk if I don't replace the accumulator/drier?
  8. #8 Re: AC condenser
    May 2016
    Rouge Island
    Chats
    3223
    Moisture in the system = less efficient output. Accumulator is cheap compared to the condenser, after all that work you're gonna want the best result, right ? Watch some YouTube vids, they explain better than I can. A few hours of casual research can go a long way towards peace of mind. Vacuum pump and manifold gauge set are a must for this job and cheap at Harbor Freight.
  9. #9 Re: AC condenser
    Oct 2014
    portland oregon
    Chats
    507
    I have the harbor freight set up now.. it's how I found where it was leaking from... I'll get the accumulator. just means the car will be down for a week since it's torn apart because the condenser is comming tomorrow. Thanks for the tips
  10. #10 Re: AC condenser
    May 2016
    Rouge Island
    Chats
    3223
    You said you filled it with compressed air, right ? You need a special vacuum pump to charge it.
  11. #11 Re: AC condenser
    Oct 2014
    portland oregon
    Chats
    507
    Yes I just hooked it up to my air compressor and used the rubber tip of my air sprayer. Closed the high and low ports below the gauges and watched as the pressure slowly left the system.
    How much does this vacuum pump with r-134a cost? The oil change place by my house will charge it for 100 bucks
  1. New condenser, then what ?
    By cheatah faheatah in forum General Tech Discussion
    Last Post: 05-06-2018, 03:49 PM
  2. Time for a new Condenser?
    By eeyan in forum Introductions/Noob Questions
    Last Post: 06-14-2017, 06:01 PM
  3. Replacing AC Condenser
    By Exile in forum General Grand Prix Discussion
    Last Post: 08-10-2016, 08:52 AM
  4. 05 GTP Condenser
    By dsteinmann in forum General Tech Discussion
    Last Post: 05-16-2011, 05:46 PM
  5. air conditioning condenser
    By Hosscat101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 06:58 AM
