Thread: intercooler budget build shortstack
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 121 to 140 of 144
  1. #121 Re: intercooler budget build shortstack
    Chats
    243824
    pump does sound well used lol
    maybe it locked up and melted the wires then. id still double check them tho.
  2. #122 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Chats
    62
    Ive attached pictures of where I grounded I had 30 going to the + on the pump seems that it even got a little hot and stuck itself to the other wires although didmt stick or get hot enough to do damage 87 going to the positive battery post 85 going to the switch in the fuse box and 86 going to the ground near the top of the car while the ground on the pump is the one near the head light Shared album - Thomas Zerilli - Google Photos
  3. #123 Re: intercooler budget build shortstack
    Chats
    243824
    ive got all my grounds going to the battery. dont trust body panels. ive got two studded terminal bolts.
    intercooler budget build shortstack Attached Images
  4. #124 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Chats
    62
    Probably a good idea wont be able to finish tonight though also had to take care of my coolant elbows leaking and have a lot to do this weekend and plenty of home work but I'll definitely follow this when I put the intercooler setup back together also what did you use to glue your barbs to the coolant resolver I used liquid nail and it seems to be leaking a hair😤
  5. #125 Re: intercooler budget build shortstack
    Chats
    243824
    i used marine epoxy. sanded the plastic and metal tubes some to scuff em up good, then sealed em up. sanding gives the epoxy something to bite into and hold better.
  6. #126 Re: intercooler budget build shortstack
    Chats
    243824
    when you cut the holes, use a 3/4 flat wood blade. works like a charm, nice clean holes.
  7. #127 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Chats
    62
    Okay cool may have to get a third bottle lol since now ive screwed up the second one maybe I can clean this one up though but I'll use that marine epoxy and sand it up as well
  8. #128 Re: intercooler budget build shortstack
    Chats
    243824
    i used a cheap dorman tank, 8 bucks iirc. welded two bolts to my rad support, and nutted the tank on that way.
  9. #129 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Chats
    62
    haven't had a chance to get to this yet hopefully I can this weekend but in the mean time Ive been having a weird intermittent squealing noise coming from my engine for the past 2 weeks. at first I noticed I had a coolant leak and figured out the coolant elbows I installed didn't seal and were spraying onto the belt well I fixed the leak but the noise is still there? belts are both relatively new and the leak is non existent now. seems to only squeal when car is fully warm and foot is off the gas. is it just a bad belt due to the overexposure to coolant or could it be something more serious. note that the car runs fine and with the windows up and music up you would never even be able to notice the issue.
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  10. #130 Re: intercooler budget build shortstack
    Kemmerer, Wyoming
    Chats
    60223
    maybe one of your tensioner pulleys is going out? or one of your other pulleys?
  11. #131 Re: intercooler budget build shortstack
    Chats
    243824
    take the oil fill cap off. if the sound goes awawsway you clogged a pcv port under the lim
  12. #132 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Chats
    62
    Pulleys are all new less than 15k miles and I have a valve cover breather cap should I just run that for a drive and if the noise goes away then I know its that right?
  13. #133 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Chats
    62
    If that fixes it should I just run it with the breather lol is it that much harm?
  14. #134 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Chats
    62
    Or I wonder if excess rtv came loose and clogged the pcv valve? That would explain why it didnt happen right away and would be an easy fix
  15. #135 Re: intercooler budget build shortstack
    Chats
    243824
    no breather. you could run a line vc to tb. but if you got a ic with working pcv, make sure the holes are clear.
    if its the pcv the sound you hear is coming from the crank seal. its sucking in air. taking the oil cap off will make it go away , if yo uput your hand over the hole, you will feel it sucking on your hand...engine running of course.
  16. #136 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Chats
    62
    yea its the ssic it has a front and rear hole in it so pcv should work fine with it correct?
  17. #137 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Chats
    62
    and that crank seal sucking in air cant be good
  18. #138 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Chats
    62
    ill check if it sucks when I get home as I said the squealing is very intermittent so it will be hard to diagnose off just the noise
  19. #139 Re: intercooler budget build shortstack
    Chats
    243824
    if its not sucking,,,take the belts off and fire it up for a min or two, see if the sound is still there, hand spin all them pulleys if the sound is gone.
    you can also wash the belts, scrub brush and hot soapy water works great.
    also make sure the belts are on the balancer all the way, ive put the sc belt on and had one rib riding the edge of the balancer. makes the tensioner really tight too.
  20. #140 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Chats
    62
    Definitely the pcv had to pull the cap off it was being sucked so hard going to look at the pcv valve now see if its jammed up in there
  1. Replies: 399
    Last Post: 08-17-2016, 01:35 PM
  2. Super cheap intercooler build. Running total $275
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2013, 12:20 PM
  3. 12 sec budget GTP
    By TwinV6GTP in forum Track Sessions and Kills
    Last Post: 06-11-2013, 09:20 AM
  4. Cam + Intercooler Deployment Build
    By sdavis11b in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2011, 08:57 PM
  5. engine build on a budget....
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2009, 10:16 PM
