Thread: intercooler budget build shortstack
Page 6 of 8 FirstFirst ... 45678 LastLast
Results 101 to 120 of 144
  1. #101 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    yeah definitely have a vac leak car went into low engine power mode 20 times today in traffic and sometimes sounds like a squirrel when idling. looks like its hitting 900+ rpm and that's triggering the low engine power mode ill be picking up that pump from harbor freight and some fat cigars and then finding this leak
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  2. #102 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Alright everyone great news vac leak was a ****ty jb weld I did to block off the exhaust gas port cant remember what it's ended up grabing a plug at menards and using some liquid nail and it sealed it right up also figured out my intercooler pump is working great and I had just the right amount of fluid to properly fill the system in letting the rubber cemet fully dry before I run the car but all should be well had to cut a hole in the fuse box cover as it was clashing with my add a fuse but that was probably the biggest problem of the day crazy I was this close and thinking of giving up couldn't have done it without you guys👍👍👍
  3. #103 Re: intercooler budget build shortstack
    Kemmerer, Wyoming
    great to hear, now go flog the car.
  4. #104 Re: intercooler budget build shortstack
    Apr 2015
    Columbus, OH
    Nice. And give her all the timing.
    Top Swapped 01 Imp
  5. #105 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    been driving it runs smooth but my pump only stayed on for about a min yesterday and I haven't heard it since did I get a bad pump off facebook is there an easy way to tell?
  6. #106 Re: intercooler budget build shortstack
    wiggle the plug, if it comes to life. get back to it, and solder the wires right to the tabs on the pump. the plug is a known POS.
    https://oi1097.photobucket.com/album...psel5ed738.jpg
  7. #107 Re: intercooler budget build shortstack
    i also cut the plastic off so i could get to the tabs there.
  8. #108 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Okay I will look at that first although it didnt seem like it cutout out seemed like it slowly got weaker then stopped
  9. #109 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    wiggled the connector never turned on and relay is clicking on and off like it should. this will be the last thing I ever buy used lol everyone is selling me broken parts and its litteraly cost me more time and money then if I just bought new and of course this guy got it from someone else and sold it so it'll be a huge hassle getting refunded for the stuff. so I might just cut my losses and get a new pump from zzp
  10. #110 Re: intercooler budget build shortstack
    you can get that same pump much cheaper off ebay.
  11. #111 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    I got it pretty cheap on amazon plus prime shipping thanks for the input though was going to ask a better place to buy if I didn't see it on amazon
  12. #112 Re: intercooler budget build shortstack
    Kemmerer, Wyoming
    hopefully a new pump fixes your problem
  13. #113 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    im sure something else will go to haha but im right there pump should come today or tomorrow but probably wont have time to touch the car till next weekend
  14. #114 Re: intercooler budget build shortstack
    you can drive it with out the pump working.
  15. #115 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Yea I know lol ive been driving it without the pump but I just took out the pump and found this happened to the pig tail after maybe 20 mins combined of this this being on most of it being short 30 sec intervals whats the issue here? This is a brand new pigtail and its fried suprised a fire didnt happen and also seems that it melted some of the 14 gauge wire I'm assuming this means bad pump but I cant imagine it would completly maul this thing in 20 mins on the pump running I did drive the car around for a week though but the pump was obviously dead so I assume it wouldnt have melted throughout the week?Shared album - Thomas Zerilli - Google Photos
  16. #116 Re: intercooler budget build shortstack
    i think you need to double check the relay set up. dotn think the pump would melt the wires up like that.
    run 12 volts off the battery right to the pump, see if it comes to life.
  17. #117 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Both the pump and connector seem to be in perfect condition just the wires completely melted did I wire this wrong?
  18. #118 Re: intercooler budget build shortstack
    something dont seem right. mines been perfect for 3 years now. never had a melt down. only issue was the plug causing the pump to turn off. so i soldered the wires right to the pump.
  19. #119 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Yea pump is fried hooked it up to my battery and nothing did the same thing to the new pump 2 sec after and it jumped in the air haha
  20. #120 Re: intercooler budget build shortstack
    Jul 2017
    macomb mi
    Old pump was also made in 2010 if that makes it not working sound more believable😭
  1. Replies: 399
    Last Post: 08-17-2016, 01:35 PM
  2. Super cheap intercooler build. Running total $275
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2013, 12:20 PM
  3. 12 sec budget GTP
    By TwinV6GTP in forum Track Sessions and Kills
    Last Post: 06-11-2013, 09:20 AM
  4. Cam + Intercooler Deployment Build
    By sdavis11b in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2011, 08:57 PM
  5. engine build on a budget....
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2009, 10:16 PM
